Dear Pololu Forum members,
I want to combine 2 VNH5019 motor controllers to control 3 motors. I edited the original VNH5019 .cpp file and .h file to use a third motor M3. However, when I try to control the third motor, it wont do anything and when I set the speed for motor 1, it controls motor 1 and 3 and go so on.
Is there a way to combine these 2 VNH5019 motor controllers to control 3 motors?
This is the code that I edited and expanded with a Motor 3.
.cpp file:
#include "DualVNH5019MotorShield.h"
// Constructors ////////////////////////////////////////////////////////////////
DualVNH5019MotorShield::DualVNH5019MotorShield()
//Pin map
_INA1 = 22;
_INB1 = 24;
_EN1DIAG1 = 26;
_CS1 = A0;
_INA2 = 28;
_INB2 = 30;
_EN2DIAG2 = 32;
_CS2 = A1;
_INA3 = 36;
_INB3 = 38;
_EN3DIAG3 = 40;
_CS1 = A2;
DualVNH5019MotorShield::DualVNH5019MotorShield(unsigned char INA1, unsigned char INB1, unsigned char EN1DIAG1, unsigned char CS1,
unsigned char INA2, unsigned char INB2, unsigned char EN2DIAG2, unsigned char CS2,
unsigned char INA3, unsigned char INB3, unsigned char EN3DIAG3, unsigned char CS3)
//Pin map
//PWM1 and PWM2 cannot be remapped because the library assumes PWM is on timer1
_INA1 = INA1;
_INB1 = INB1;
_EN1DIAG1 = EN1DIAG1;
_CS1 = CS1;
_INA2 = INA2;
_INB2 = INB2;
_EN2DIAG2 = EN2DIAG2;
_CS2 = CS2;
_INA3 = INA3;
_INB3 = INB3;
_EN3DIAG3 = EN3DIAG3;
_CS3 = CS3;
// Public Methods //////////////////////////////////////////////////////////////
void DualVNH5019MotorShield::init()
// Define pinMode for the pins and set the frequency for timer1.
pinMode(_INA1,OUTPUT);
pinMode(_INB1,OUTPUT);
pinMode(_PWM1,OUTPUT);
pinMode(_EN1DIAG1,INPUT);
pinMode(_CS1,INPUT);
pinMode(_INA2,OUTPUT);
pinMode(_INB2,OUTPUT);
pinMode(_PWM2,OUTPUT);
pinMode(_EN2DIAG2,INPUT);
pinMode(_CS2,INPUT);
pinMode(_INA3,OUTPUT);
pinMode(_INB3,OUTPUT);
pinMode(_PWM3,OUTPUT);
pinMode(_EN3DIAG3,INPUT);
pinMode(_CS3,INPUT);
#if defined(__AVR_ATmega168__)|| defined(__AVR_ATmega328P__)
// Timer 1 configuration
// prescaler: clockI/O / 1
// outputs enabled
// phase-correct PWM
// top of 400
// PWM frequency calculation
// 16MHz / 1 (prescaler) / 2 (phase-correct) / 400 (top) = 20kHz
TCCR1A = 0b10100000;
TCCR1B = 0b00010001;
ICR1 = 400;
#endif
// Set speed for motor 1, speed is a number betwenn -400 and 400
void DualVNH5019MotorShield::setM1Speed(int speed)
unsigned char reverse = 0;
if (speed < 0)
speed = -speed; // Make speed a positive quantity
reverse = 1; // Preserve the direction
if (speed > 400) // Max PWM dutycycle
speed = 400;
OCR1A = speed;
#else
analogWrite(_PWM1,speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
if (speed == 0)
digitalWrite(_INA1,LOW); // Make the motor coast no
digitalWrite(_INB1,LOW); // matter which direction it is spinning.
else if (reverse)
digitalWrite(_INB1,HIGH);
else
digitalWrite(_INA1,HIGH);
// Set speed for motor 2, speed is a number betwenn -400 and 400
void DualVNH5019MotorShield::setM2Speed(int speed)
if (speed < 0)
speed = -speed; // make speed a positive quantity
reverse = 1; // preserve the direction
speed = 400;
OCR1B = speed;
#else
analogWrite(_PWM2,speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
if (speed == 0)
digitalWrite(_INA2,LOW); // Make the motor coast no
digitalWrite(_INB2,LOW); // matter which direction it is spinning.
else if (reverse)
digitalWrite(_INB2,HIGH);
else
digitalWrite(_INA2,HIGH);
// Set speed for motor 3, speed is a number betwenn -400 and 400
void DualVNH5019MotorShield::setM3Speed(int speed)
if (speed < 0)
speed = 400;
OCR1C = speed;
#else
analogWrite(_PWM3,speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
if (speed == 0)
digitalWrite(_INA3,LOW); // Make the motor coast no
digitalWrite(_INB3,LOW); // matter which direction it is spinning.
else if (reverse)
digitalWrite(_INB3,HIGH);
else
digitalWrite(_INA3,HIGH);
// Set speed for motor 1 and 2
void DualVNH5019MotorShield::setSpeeds(int m1Speed, int m2Speed)
setM1Speed(m1Speed);
setM2Speed(m2Speed);
// Set speed for motor 1 and 3
void DualVNH5019MotorShield::setSpeeds3(int m1Speed, int m3Speed)
setM3Speed(m3Speed);
// Set speed for motor 2 and 3
void DualVNH5019MotorShield::setSpeeds2(int m2Speed, int m3Speed)
// Set speed for motor 1, 2 and 3
void DualVNH5019MotorShield::setSpeedsAll(int m1Speed, int m2Speed, int m3Speed)
// Brake motor 1, brake is a number between 0 and 400
void DualVNH5019MotorShield::setM1Brake(int brake)
// normalize brake
if (brake < 0)
brake = -brake;
if (brake > 400) // Max brake
brake = 400;
digitalWrite(_INA1, LOW);
digitalWrite(_INB1, LOW);
OCR1A = brake;
#else
analogWrite(_PWM1,brake * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
// Brake motor 2, brake is a number between 0 and 400
void DualVNH5019MotorShield::setM2Brake(int brake)
// normalize brake
if (brake < 0)
brake = -brake;
brake = 400;
digitalWrite(_INA2, LOW);
digitalWrite(_INB2, LOW);
OCR1B = brake;
#else
analogWrite(_PWM2,brake * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
// Brake motor 3, brake is a number between 0 and 400
void DualVNH5019MotorShield::setM3Brake(int brake)
// normalize brake
if (brake < 0)
brake = -brake;
brake = 400;
digitalWrite(_INA3, LOW);
digitalWrite(_INB3, LOW);
OCR1C = brake;
#else
analogWrite(_PWM3,brake * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
// Brake motor 1 and 2, brake is a number between 0 and 400
void DualVNH5019MotorShield::setBrakes(int m1Brake, int m2Brake)
setM1Brake(m1Brake);
setM2Brake(m2Brake);
// Brake motor 2 and 3, brake is a number between 0 and 400
void DualVNH5019MotorShield::setBrakes2(int m2Brake, int m3Brake)
setM3Brake(m3Brake);
// Brake motor 1 and 3, brake is a number between 0 and 400
void DualVNH5019MotorShield::setBrakes3(int m1Brake, int m3Brake)
// Brake motor 1, 2 and 3, brake is a number between 0 and 400
void DualVNH5019MotorShield::setBrakesAll(int m1Brake, int m2Brake, int m3Brake)
// Return motor 1 current value in milliamps.
unsigned int DualVNH5019MotorShield::getM1CurrentMilliamps()
// 5V / 1024 ADC counts / 144 mV per A = 34 mA per count
return analogRead(_CS1) * 34;
// Return motor 2 current value in milliamps.
unsigned int DualVNH5019MotorShield::getM2CurrentMilliamps()
return analogRead(_CS2) * 34;
// Return motor 3 current value in milliamps.
unsigned int DualVNH5019MotorShield::getM3CurrentMilliamps()
return analogRead(_CS3) * 34;
// Return error status for motor 1
unsigned char DualVNH5019MotorShield::getM1Fault()
return !digitalRead(_EN1DIAG1);
// Return error status for motor 2
unsigned char DualVNH5019MotorShield::getM2Fault()
return !digitalRead(_EN2DIAG2);
// Return error status for motor 3
unsigned char DualVNH5019MotorShield::getM3Fault()
return !digitalRead(_EN3DIAG3);
.h file
#ifndef DualVNH5019MotorShield_h
#define DualVNH5019MotorShield_h
#include <Arduino.h>
class DualVNH5019MotorShield
public:
// CONSTRUCTORS
DualVNH5019MotorShield(); // Default pin selection.
unsigned char INA3, unsigned char INB3, unsigned char EN2DIAG3, unsigned char CS3); // User-defined pin selection.
// PUBLIC METHODS
void init(); // Initialize TIMER 1, set the PWM to 20kHZ.
void setM1Speed(int speed); // Set speed for M1.
void setM2Speed(int speed); // Set speed for M2.
void setM3Speed(int speed); // Set speed for M2.
void setSpeeds(int m1Speed, int m2Speed); // Set speed for both M1 and M2.
void setSpeeds2(int m2Speed, int m3Speed); // Set speed for both M1 and M2.
void setSpeeds3(int m1Speed, int m3Speed); // Set speed for both M1 and M2.
void setSpeedsAll(int m1Speed, int m2Speed, int m3Speed); // Set speed for both M1 and M2.
void setM1Brake(int brake); // Brake M1.
void setM2Brake(int brake); // Brake M2.
void setM3Brake(int brake); // Brake M2.
void setBrakes(int m1Brake, int m2Brake); // Brake both M1 and M2.
void setBrakes2(int m2Brake, int m3Brake); // Brake both M1 and M2.
void setBrakes3(int m1Brake, int m3Brake); // Brake both M1 and M2.
void setBrakesAll(int m1Brake, int m2Brake, int m3Brake); // Brake both M1 and M2.
unsigned int getM1CurrentMilliamps(); // Get current reading for M1.
unsigned int getM2CurrentMilliamps(); // Get current reading for M2.
unsigned int getM3CurrentMilliamps(); // Get current reading for M2.
unsigned char getM1Fault(); // Get fault reading from M1.
unsigned char getM2Fault(); // Get fault reading from M2.
unsigned char getM3Fault(); // Get fault reading from M2.
private:
unsigned char _INA1;
unsigned char _INB1;
static const unsigned char _PWM1 = 2;
unsigned char _EN1DIAG1;
unsigned char _CS1;
unsigned char _INA2;
unsigned char _INB2;
static const unsigned char _PWM2 = 3;
unsigned char _EN2DIAG2;
unsigned char _CS2;
unsigned char _INA3;
unsigned char _INB3;
static const unsigned char _PWM3 = 4;
unsigned char _EN3DIAG3;
unsigned char _CS3;
#endif
Can you guys help me out?
