I have a motor that only have a positive cable. The negative side is the chassis. Is it possible to combine ground and negative side of the motor with the controllers/drivers?
Best regards
Peter Axelsson
Best regards
Peter Axelsson
In general, no, and especially not if you want the motor to rotate in both directions.
If you can electrically isolate the motor chassis from power/system ground, then just use the motor chassis as one terminal.
