I have recently purchased the SMC 18v7 along with a motor and battery. The motor runs fine when I connected it with USB to my PC and I am able to control its speed via the graphical user interface.
I have also chanced upon that there are 2 programming examples (SmcExample1 and SmcExample2) in the SDK that I have downloaded. I understand that these two examples are in C#, so, I would like to ask if and how is it possible to convert (in any way) to a C++ language in Linux?
The reason why I want to change it to C++ is because I want to use the C++ code as my subprogram in a project that I am doing, which can only be used in C++.
For Linux, you might consider using libusb to send appropriate commands to your Simple Motor Controller (SMC). You can read the code in the Pololu USB SDK as a guide to help you understand the USB protocol of the Simple Motor Controller, and then implement the same thing in C++ with libusb.
