I have connected 3 Sharp Sensors to the ADC7,ADC6,and PC5 ports.Then I removed the ADC7,ADC6,and PC5 jumpers.I’ve modified the Wall Following code to work with 3 sensors.
But the sensor that is connected to ADC6 doesn’t work.
Here is the code:
#include <pololu/3pi.h>
// This include file allows data to be stored in program space. The
// ATmegaxx8 has 16x more flash than RAM, so large
// pieces of static data should be stored in program space.
#include <avr/pgmspace.h>
// Introductory messages. The "PROGMEM" identifier causes the data to
// go into program space.
const char welcome_line1[] PROGMEM = " Pololu";
const char welcome_line2[] PROGMEM = "3\xf7 Robot";
const char name_line1[] PROGMEM = "Sharp";
const char name_line2[] PROGMEM = "Sensors";
// A couple of simple tunes, stored in program space.
const char welcome[] PROGMEM = ">g32>>c32";
const char go[] PROGMEM = "L16 cdegreg4";
// Refresh the LCD display every tenth of a second.
const int display_interval_ms = 100;
#define MS_ELAPSED_IS(n) (get_ms() % n == 0)
#define TIME_TO_DISPLAY (MS_ELAPSED_IS(display_interval_ms))
void initialize()
// Set PC5 as an input with internal pull-up disabled
DDRC &= ~(1<< PORTC5);
PORTC &= ~(1<< PORTC5);
// Play welcome music and display a message
print_from_program_space(welcome_line1);
lcd_goto_xy(0,1);
print_from_program_space(welcome_line2);
play_from_program_space(welcome);
delay_ms(1000);
clear();
print_from_program_space(name_line1);
lcd_goto_xy(0,1);
print_from_program_space(name_line2);
delay_ms(1000);
// Display battery voltage and wait for button press
while(!button_is_pressed(BUTTON_B))
clear();
print_long(read_battery_millivolts());
print("mV");
lcd_goto_xy(0,1);
print("Press B");
delay_ms(100);
// Always wait for the button to be released so that 3pi doesn't
// start moving until your hand is away from it.
wait_for_button_release(BUTTON_B);
clear();
print("Go!");
// Play music and wait for it to finish before we start driving.
play_from_program_space(go);
while(is_playing());
void back_up()
if (TIME_TO_DISPLAY)
clear();
lcd_goto_xy(0,0);
print("Backing");
lcd_goto_xy(0,1);
print("Up");
// Back up slightly to the left
set_motors(-50,-75);
void turn_in_place() {
if (TIME_TO_DISPLAY) {
clear();
lcd_goto_xy(0,0);
print("Front");
lcd_goto_xy(0,1);
print("Obstacle");
// Turn to the right
set_motors(90, 50);
int main()
// set up the 3pi
initialize();
int last_proximity = 0;
//const int base_speed = 75;
//const int set_point = 100;
// This is the "main loop" - it will run forever.
while(1)
//In case it gets stuck: for 1 second every 15 seconds back up
if (get_ms() % 15000 > 14000) {
back_up();
continue;
// If something is directly in front turn to the right in place
int front_proximity = analog_read(5);
if (front_proximity > 150) {
turn_in_place();
continue;
int close_proximity = analog_read(6);
if(close_proximity < 300) {
turn_in_place();
continue;
int proximity = analog_read(7);
int proportional = proximity - set_point;
int derivative = proximity - last_proximity;
// Proportional-Derivative Control Signal
int pd = proportional / 3 + derivative * 20;
int left_set = base_speed + pd;
int right_set = base_speed - pd;
set_motors(left_set, right_set);
clear();
lcd_goto_xy(0,0);
print_long(proximity);
lcd_goto_xy(5,0);
print_long(pd);
lcd_goto_xy(0,1);
print_long(left_set);
lcd_goto_xy(4,1);
print_long(right_set);
last_proximity = proximity; // remember last proximity for derivative
// This part of the code is never reached. A robot should
// never reach the end of its program, or unpredictable behavior
// will result as random code starts getting executed. If you
// really want to stop all actions at some point, set your motors
// to 0,0 and run the following command to loop forever:
// while(1);
Please help.
Thanks.
