I’ve got a stepper motor hooked up to a Raspberry Pi using the A4988 driver. I’ve made a little python script that controls the SLEEP and STEP pins, so I can make the motor rotate and also put it to sleep. DIR and RESET are always HIGH resp. LOW.
I’ve attached a drawing of the wiring below.
Now I have two questions:
1/ when nothing’s hooked up to the STEP, the motor is rotating out of it’s own. Now that may be normal (?) as the specs tell not to leave STEP floating. (btw, I have the impression it’s responding to a fake STEP signal of someting in the range of 10-100 Hz, maybe the 60Hz power frequence is popping in somehow??)
2/ when booting up the raspberry pi, all pins are floating, but I’d like my motor NOT to start rotating until I tell it so. This is how I think to proceed: connect the VDD to some other Raspberry output pin (i.o. the 3.3V pin now), which will be also floating during boot, but which may prevent the driver from starting up at all, until I set the VDD-pin to high and take control.
So my question: what would happen if I connect VDD to a floating Raspberry pin? Will this prevent the driver from rotating the motor based on an equally floating STEP signal?
Or should I take another approach?
Best regards,
Vic
wiring scheme : https://goo.gl/photos/NrKmEvMU2GnGPwsMA
