ATX Computer power supply 12V (Yellow wires) off the PSU, running the 12V rail to the Stepper driver VMOT and gnd.
Driver IC heated up while it was jittering so I switched off the psu.
Using the code and wiring diagram from this post A4983 and A4988 Getting Started Guide
possible I have the meter hooked up improperly but only see random values jump around on the meter while it was inline with one of the coils so there wasnt much I could do to set a common value on the current delimit pot.
This might not help but I had the meter setup like this:
[Pololu 2A] -> [Motor Coil 2A] ->
[Motor Coil 2B] -> [MultiMeter Amp Red Probe] ->
[MultiMeter COM Black Probe] -> [Pololu 2B]
I will see If I can get a picture when my batteries are charged.
