Dear Manager.
Hi, I’m using this motor drive
https://www.pololu.com/blog/394/two-new-motor-driver-shields-for-arduino
I have questions about using the product.
The PWM control pin of the motor drive is confirmed by 9 & 10. In your provided library (CPP & H file)
I want to change the Pin number Pin 9 -> Pin 6
because I use motor drive and LCD together.
However, the LCD also uses Pin 9. Therefore, they are nested.
I have tried several methods.
1.
- const unsigned char DRV8835MotorShield :: _ M1PWM = 6; // 9 From the cpp file … and just save the file
- Connect Pin 9 of Motor Driver to Pin 6 of Arduino
== The motor did not move…
- Arduino Pin9 and drive Pin 9
- just change source code cpp, 9->6
- cpp, Do not modify source code
- change pin number, Arduino pin6 and drive pin 6
So,!!! I don’t know how to use Pin 6!!!
please help me…
thank you
