i have 36v4 connected to Teensy 4.0. i am running arduino BasicSteppingSpi example. i have modified it slightly per my connections.
i do not have motor connected. i always receive 0x20 status.
i thought perhaps i fried my first 36v4 so i ordered a second one. same result and second one i have not connected motor and only run BasicSteppingSpi example.
measuring with DVM referenced to GND:
IOREF = 3.27V
GND = 0.0V
!SLEEP = 3.27V
VIN = 24.1V
-----below is printf log-----
readStatus 0x20
readFaults 0x20
post readStatus 0x20
post readFaults 0x20
readStatus 0x20
readFaults 0x20
readStatus 0x20
readFaults 0x20
readStatus 0x20
readFaults 0x20
----below is example i have modified-----
/ This example shows basic use of a Pololu High Power Stepper Motor Driver.
// It shows how to initialize the driver, configure various settings, and enable
// the driver. It shows how to step the motor and switch directions using the
// driver's SPI interface through the library's step() and setDirection() member
// functions.
// Since SPI is used to trigger steps and set the direction, connecting the
// driver's STEP and DIR pins is optional for this example. However, note that
// using SPI control adds some overhead compared to using the STEP and DIR pins.
// In addition, since the library caches SPI register values, SPI control is
// more likely to re-enable the driver with the wrong settings (e.g. current
// limit) after a power interruption, although using the verifySettings() and
// applySettings() functions appropriately can help prevent this.
// Before using this example, be sure to change the setCurrentMilliamps36v4 line
// to have an appropriate current limit for your system. Also, see this
// library's documentation for information about how to connect the driver:
// http://pololu.github.io/high-power-stepper-driver
#include <SPI.h>
#include <HighPowerStepperDriver.h>
//const uint8_t CSPin = 4;
const uint8_t CSPin = 10;
// This period is the length of the delay between steps, which controls the
// stepper motor's speed. You can increase the delay to make the stepper motor
// go slower. If you decrease the delay, the stepper motor will go faster, but
// there is a limit to how fast it can go before it starts missing steps.
const uint16_t StepPeriodUs = 2000;
HighPowerStepperDriver sd;
const int LeftStepperSleep = 8;
void setup()
pinMode(LeftStepperSleep, OUTPUT);
digitalWrite(LeftStepperSleep, HIGH); //
SPI.begin();
sd.setChipSelectPin(CSPin);
// Give the driver some time to power up.
delay(1);
// Reset the driver to its default settings and clear latched status
// conditions.
sd.resetSettings();
sd.clearStatus();
// Select auto mixed decay. TI's DRV8711 documentation recommends this mode
// for most applications, and we find that it usually works well.
sd.setDecayMode(HPSDDecayMode::AutoMixed);
// Set the current limit. You should change the number here to an appropriate
// value for your particular system.
sd.setCurrentMilliamps36v4(500);
// Set the number of microsteps that correspond to one full step.
sd.setStepMode(HPSDStepMode::MicroStep32);
//sd.clearFaults();
//sd.clearStatus();
// Enable the motor outputs.
sd.enableDriver();
// digitalWrite(LeftStepperSleep, HIGH); //
void loop()
// Step in the default direction 1000 times.
sd.setDirection(0);
for(unsigned int x = 0; x < 1000; x++)
sd.step();
delayMicroseconds(StepPeriodUs);
Serial.printf("readStatus 0x%x \n",sd.readStatus());
Serial.printf("readFaults 0x%x \n",sd.readFaults());
sd.clearFaults();
sd.clearStatus();
Serial.printf("post readStatus 0x%x \n",sd.readStatus());
Serial.printf("post readFaults 0x%x \n",sd.readFaults());
// Wait for 300 ms.
delay(300);
// Step in the other direction 1000 times.
sd.setDirection(1);
sd.step();
// Wait for 300 ms.
delay(300);
