Hi, I have a 1971 Nova and I am trying to use a small actuator to set and release the parking brake by using a button on the dash. I am a computer guy, but this is my first time playing with a motor controller. So please be kind. I am trying to do this with the JrK G2 18V27 controller. My plan was to have a momentary contact switch mounted in the dash. Press the switch up and the actuator retracts, pulling on the brake cables. When you push the button down the actuator extends and releases the parking brake. I like the idea of a quick momentary press of the button to cause a change to happen.
In the car I have a Dakota Digital Dash that has an indicator light for the parking brake. The light is activated by a ground signal. I think the AUX port is 5V. I was trying to use the relay module to provide a switched ground. I couldn’t figure that out at all. I thought I would be able to configure and control the AUX port from the software but figured out I can’t.
If I mess around with the software settings, I can get the actuator to extend and retract. It just won’t latch and dash indicator does not work. In other words, release the button and actuator extends. I am thinking that I need to figure out how to wire in the DPST latching relay linked below
DPDT latching relay - Yctze DPDT Relay Module Double Pole Double Throw Self Locking Bistable Relay Board for ESP, 12V, 5V Single Pole, 4V to 6V, Latching Relay (DC6-24V) : Amazon.ca: Tools & Home Improvement
Relay module - Yctze DPDT Relay Module Double Pole Double Throw Self Locking Bistable Relay Board for ESP, 12V, 5V Single Pole, 4V to 6V, Latching Relay (DC6-24V) : Amazon.ca: Tools & Home Improvement
Switch momentary rocker DPDT - HYY Momentary ON Off ON Rocker Switch Control DPDT DC 12V or 24V : Amazon.ca: Sports & Outdoors
Actuator - HYY Momentary ON Off ON Rocker Switch Control DPDT DC 12V or 24V : Amazon.ca: Sports & Outdoors
Electric Parking Brake Wiring - Jrk G2 board.pdf (276.9 KB)
Thanks for any help you can provide
Chris
