Does anyone know the sleep current for the 18V25. e.g when the SLP is asserted.
I am also interested in the current consumption of the motor controller when the motor current is zero. In this case SLP will not be asserted and PWM = L. Maybe I can save a pin and not use SLP.
It sounds like you are talking about our G2 High-Power Motor Driver 18v25.
The board consumes about 15mA normally. When in sleep mode, the current consumption is driven primarily by a 100k resistor that pulls the SLP pin high, so if VIN is 10V, the board will consume about 100uA.
