https://www.pololu.com/catalog/product/1125
This motor says recommended range is 3-6V. I have the 7.2v NIMH sold here. Will 7.2 burn up the motor? Battery will drop to around 6v during mid range, but is fresh is above 7v. Thanks much.
That voltage should be fine. In general, the lower voltage you run a motor at the longer it will last.
- Ryan
