Does anyone have the code to convert the A value given by the accelerometer on an LSM303 on a Zumo32U4? I want to convert the raw A value into distance/seconds^2.
If not, can someone send the datasheet with the conversions? I’m struggling to find it on the internet
If you just print out the raw sensor readings, do you see the Z axis reporting values in the 16 thousands as it should be reading 1g? It appears that dividing the raw readings by 16384 (2^14) should give you the acceleration reading in g which can then be converted to m/s^2 by multiplying by 9.8
To get distance from acceleration requires double integration. Any error in the accelerometer measurement will be twice integrated and accumulated in your distance estimate. Those accumulated errors means it isn’t a robust approach for distance estimation.
