Hi, i’m trying to create a script for my Zumo robot which will use WASD controls to go forward, turn left and right, and reverse. Using motor.setSpeeds seems to be working but using a hyphen before the variable or speed set doesn’t set the motor into reverse, it only goes forward still.
I have posted my code below if anyone would like to look - any help or guidance would be appreciated with this, many thanks!
#include <Wire.h>
#include <ZumoShield.h>
#include <ZumoMotors.h>
// Zumo32U4ButtonA buttonA;
// Documentation for the motors class:
// http://pololu.github.io/zumo-32u4-arduino-library/class_zumo32_u4_motors.html
ZumoMotors motors;
#define QTR_THRESHOLD 1500
#define NUM_SENSORS 6
#define MOTOR_SPEED 100
bool onOff = true;
unsigned int sensor_values[NUM_SENSORS];
ZumoReflectanceSensorArray sensors(QTR_NO_EMITTER_PIN);
void setup() {
Serial1.begin(9600);
Serial.begin(9600);
void loop() {
while (Serial1.available()>0) {
int direction = Serial1.read();
Serial.print("Got message: ");
Serial.println(direction);
String name ="";
switch (direction){
case'w': case 'W':
name = "Forward";
motors.setSpeeds(MOTOR_SPEED, MOTOR_SPEED);
delay(250);
motors.setSpeeds(0, 0);
break;
case'a': case 'A':
name = "Left";
motors.setSpeeds(-MOTOR_SPEED, MOTOR_SPEED);
delay(115);
break;
case'd': case 'D':
name = "Right";
motors.setSpeeds(MOTOR_SPEED, -MOTOR_SPEED);
delay(115);
break;
case's': case 'S':
name = "Backwards";
motors.setSpeeds(-MOTOR_SPEED, -MOTOR_SPEED);
delay(250);
break;
case'z': case 'Z':
name = "Stop";
break;
