So I got a couple of Zumos, put them together with Arduinos, and loved them. I wanted to use them as a base for other projects, but when I got the “Expansion Plate” I don’t see a way to mount them without drilling a hole through the power button of the Arduino Uno. There are two screws that are exposed and can be used to mount the plate, but both of the other screws are under the Arduino.
Has anyone else come across this and found a workaround? The plate I am talking about can be found at pololu.com/product/1531 . Without heavily modification that will probably break either the Arduino or the Zumo i don’t see how it should be mounted. Any advice would be appreciated.
Thanks in advance,
OmegaNine
