I’ve done something similar with PID and I found the best way to debug it is to log everything to the serial output so you can see what is going on.
I also log to CSV format so I can create graphs in a spread sheet. For example, here is code I’ve used:
void resetPID()
pid_total_lticks = 0;
pid_total_rticks = 0;
pid_lastErr = 0;
pid_sumErrs = 0;
adjustLMotor = adjustRMotor = 0;
updateMotors();
clear_ticks();
pid_time = 0;
#if CSV_OUTPUT && PID_INFO
Serial.print("PID Reset: System Bias = ");
Serial.println(SYSTEM_BIAS);
Serial.println("Time, Interval, Left Ticks, Right Ticks, Error, Sum Erros, Adjust, Left, Adjust Right");
#endif
void driveStraight()
static int16_t lticks = 0, rticks = 0;
static uint16_t ms = 0;
int16_t dlticks, drticks, diff;
int32_t delta;
uint16_t dms;
get_ticks_since_last( &dlticks, &drticks, &dms);
lticks += dlticks;
rticks += drticks;
pid_total_lticks += dlticks;
pid_total_rticks += drticks;
ms += dms;
pid_time += dms;
if ( ms > 200 )
int16_t rdir = rticks < 0 ? -1 : 1;
int16_t ldir = lticks < 0 ? -1 : 1;
// make the values positive
lticks *= ldir;
rticks *= rdir;
int16_t bias = (rticks*SYSTEM_BIAS)/10000L;
diff = ((lticks - rticks + bias )*100L)/ms;
// we want the difference to be 0
// track the integral
pid_sumErrs += diff;
// get the differential
delta = (int32_t) (diff - pid_lastErr);
int16_t P = (int16_t) ((Kp*((int32_t)diff) + Ki*((int32_t)pid_sumErrs) + (Kd*delta))/1000L);
pid_lastErr = diff;
// a positive error means the left motor is
// turning more than the right so adjust
// each motor accordingly
int16_t adjust = (P>>1);
adjustLMotor -= adjust*ldir;
adjustRMotor += adjust*rdir;
// Put a limit on the total adjustment in case PID gets out of control
constrain( adjustLMotor, -MAX_ADJUSTMENT, MAX_ADJUSTMENT);
constrain( adjustRMotor, -MAX_ADJUSTMENT, MAX_ADJUSTMENT);
#if PID_INFO
#if CSV_OUTPUT
Serial.print(pid_time); Serial.print(", ");
Serial.print(ms); Serial.print(", ");
Serial.print(lticks); Serial.print(", ");
Serial.print(rticks); Serial.print(", ");
Serial.print(diff); Serial.print(", ");
Serial.print(pid_sumErrs); Serial.print(", ");
Serial.print(adjustLMotor); Serial.print(", ");
Serial.print(adjustRMotor);
Serial.println();
#else
Serial.print("DIFF = ");
Serial.print(diff);
Serial.print(" ERR = ");
Serial.print(" ADJ = (");
Serial.print(", ");
Serial.println(")");
#endif
#endif
updateMotors();
lticks = 0;
rticks = 0;
ms = 0;
Pretty simple.
You can see some of the graphs I was able to produced here : wp.me/p493sy-dQ
Was very helpful for figuring out my bugs.
Even if your PID control is working properly I think there might be an issue with the compass. I’ve only played with the Zumo compass a little but I noticed that the readings are greatly effected by the indoor environment. I would create a sketch that just continually prints the heading and manually move the bot in straight lines to see if the heading stays constant.
BTW, I recommend getting a bluetooth module if you don’t already have one. It’s great not having to tether your laptop to the bot when trying to collect data. You can get them for around $10 on amazon.
