Good Evening All
I have been taking up zumo 32U4 robot for a month and i am so new on this subject. Firstly, i assemblied the zumo32U4 kit and then i downloaded a program which an example is in file>examples> zumo32u4>sumocollisiondetect. However, the robot can detect black surface and white line, it doesn’t trace and search opponent one, detects a crash so late( it behaves as a crazy and just goes left right behind etc.) . Therefore , my robot became last at the contest.
Now i found a program about proximity sensors and compiled with the other collision example.
#include <avr/pgmspace.h>
#include <Wire.h>
#include <Zumo32U4.h>
// #define LOG_SERIAL // write log output to serial port
Zumo32U4LCD lcd;
Zumo32U4ProximitySensors proxSensors;
Zumo32U4ButtonA button;
// Accelerometer Settings
#define RA_SIZE 3 // number of readings to include in running average of accelerometer readings
#define XY_ACCELERATION_THRESHOLD 2400 // for detection of contact (~16000 = magnitude of acceleration due to gravity)
// Reflectance Sensor Settings
#define NUM_SENSORS 5
unsigned int sensor_values[NUM_SENSORS];
// this might need to be tuned for different lighting conditions, surfaces, etc.
#define QTR_THRESHOLD 1000 // microseconds
Zumo32U4LineSensors sensors;
// Motor Settings
Zumo32U4Motors motors;
// these might need to be tuned for different motor types
#define REVERSE_SPEED 300 // 0 is stopped, 400 is full speed
#define TURN_SPEED 401
#define SEARCH_SPEED 203
#define SUSTAINED_SPEED 400 // switches to SUSTAINED_SPEED from FULL_SPEED after FULL_SPEED_DURATION_LIMIT ms
#define FULL_SPEED 406
#define STOP_DURATION 100 // ms
#define REVERSE_DURATION 200 // ms
#define TURN_DURATION 300 // ms
#define RIGHT 1
#define LEFT -1
enum ForwardSpeed { SearchSpeed, SustainedSpeed, FullSpeed };
ForwardSpeed _forwardSpeed; // current forward speed setting
unsigned long full_speed_start_time;
#define FULL_SPEED_DURATION_LIMIT 252 // ms
// Sound Effects
Zumo32U4Buzzer buzzer;
const char sound_effect[] PROGMEM = "O4 T100 V15 L4 MS g12>c12>e12>G6>E12 ML>G2"; // "charge" melody
// use V0 to suppress sound effect; v15 for max volume
// Timing
unsigned long loop_start_time;
unsigned long last_turn_time;
unsigned long contact_made_time;
#define MIN_DELAY_AFTER_TURN 400 // ms = min delay before detecting contact event
#define MIN_DELAY_BETWEEN_CONTACTS 1000 // ms = min delay between detecting new contact event
// RunningAverage class
// based on RunningAverage library for Arduino
// source: http://playground.arduino.cc/Main/RunningAverage
template <typename T>
class RunningAverage
public:
RunningAverage(void);
RunningAverage(int);
~RunningAverage();
void clear();
void addValue(T);
T getAverage() const;
void fillValue(T, int);
protected:
int _size;
int _cnt;
int _idx;
T _sum;
T * _ar;
static T zero;
// Accelerometer Class -- extends the LSM303 class to support reading and averaging the x-y acceleration
// vectors from the onboard LSM303DLHC accelerometer/magnetometer
class Accelerometer : public LSM303
typedef struct acc_data_xy
unsigned long timestamp;
int x;
int y;
float dir;
} acc_data_xy;
public:
Accelerometer() : ra_x(RA_SIZE), ra_y(RA_SIZE) {};
~Accelerometer() {};
void enable(void);
void getLogHeader(void);
void readAcceleration(unsigned long timestamp);
float len_xy() const;
float dir_xy() const;
int x_avg(void) const;
int y_avg(void) const;
long ss_xy_avg(void) const;
float dir_xy_avg(void) const;
private:
acc_data_xy last;
RunningAverage<int> ra_x;
RunningAverage<int> ra_y;
Accelerometer lsm303;
boolean in_contact; // set when accelerometer detects contact with opposing robot
// forward declaration
void setForwardSpeed(ForwardSpeed speed);
void setup()
proxSensors.initThreeSensors();
sensors.initFiveSensors();
// Initialize the Wire library and join the I2C bus as a master
Wire.begin();
// Initialize LSM303
lsm303.init();
lsm303.enable();
#ifdef LOG_SERIAL
lsm303.getLogHeader();
#endif
randomSeed((unsigned int) millis());
// Uncomment if necessary to correct motor directions:
//motors.flipLeftMotor(true);
//motors.flipRightMotor(true);
ledYellow(1);
buzzer.playMode(PLAY_AUTOMATIC);
waitForButtonAndCountDown(false);
void waitForButtonAndCountDown(bool restarting)
#ifdef LOG_SERIAL
Serial.print(restarting ? "Restarting Countdown" : "Starting Countdown");
Serial.println();
#endif
ledRed(0);
ledYellow(1);
lcd.clear();
lcd.print(F("robocop A"));
button.waitForButton();
ledYellow(0);
lcd.clear();
// play audible countdown
for (int i = 0; i < 4; i++)
delay(1000);
buzzer.playNote(NOTE_G(3), 50, 12);
delay(1000);
buzzer.playFromProgramSpace(sound_effect);
delay(1000);
// reset loop variables
in_contact = false; // 1 if contact made; 0 if no contact or contact lost
contact_made_time = 0;
last_turn_time = millis(); // prevents false contact detection on initial acceleration
_forwardSpeed = SearchSpeed;
full_speed_start_time = 0;
void loop()
if (button.isPressed())
// if button is pressed, stop and wait for another press to go again
motors.setSpeeds(0, 0);
button.waitForRelease();
waitForButtonAndCountDown(true);
loop_start_time = millis();
lsm303.readAcceleration(loop_start_time);
sensors.read(sensor_values);
if ((_forwardSpeed == FullSpeed) && (loop_start_time - full_speed_start_time > FULL_SPEED_DURATION_LIMIT))
setForwardSpeed(SustainedSpeed);
if (sensor_values[0] < QTR_THRESHOLD)
// if leftmost sensor detects line, reverse and turn to the right
turn(RIGHT, true);
else if (sensor_values[NUM_SENSORS - 1] < QTR_THRESHOLD)
// if rightmost sensor detects line, reverse and turn to the left
turn(LEFT, true);
else // otherwise, go straight
if (check_for_contact()) on_contact_made();
int speed = getForwardSpeed();
motors.setSpeeds(speed, speed);
void turnToStrongestProx()
int left,frontLeft,frontRight,right;
int error;
proxSensors.read();
left=proxSensors.countsLeftWithLeftLeds();
frontLeft=proxSensors.countsFrontWithLeftLeds();
frontRight=proxSensors.countsFrontWithRightLeds();
right=proxSensors.countsRightWithRightLeds();
if(left>frontLeft&&left>frontRight&&left>=right) {
motors.setSpeeds(-TURN_SPEED,TURN_SPEED);
do {
proxSensors.read();
} while (proxSensors.countsFrontWithLeftLeds()<left);
} else if(right>frontLeft&&right>frontRight&&right>left) {
motors.setSpeeds(TURN_SPEED,-TURN_SPEED);
do {
proxSensors.read();
} while (proxSensors.countsFrontWithRightLeds()<right);
do {
proxSensors.read();
error=proxSensors.countsFrontWithRightLeds()-proxSensors.countsFrontWithLeftLeds();
if(error>0){
} else if(error<0) {
} while (error!=0);
buzzer.playFrequency(440, 200, 15);
motors.setSpeeds(0,0);
// execute turn
// direction: RIGHT or LEFT
// randomize: to improve searching
void turn(char direction, bool randomize)
#ifdef LOG_SERIAL
Serial.print("turning ...");
Serial.println();
#endif
// assume contact lost
on_contact_lost();
static unsigned int duration_increment = TURN_DURATION / 4;
// motors.setSpeeds(0,0);
// delay(STOP_DURATION);
motors.setSpeeds(-REVERSE_SPEED, -REVERSE_SPEED);
delay(REVERSE_DURATION);
motors.setSpeeds(TURN_SPEED * direction, -TURN_SPEED * direction);
delay(randomize ? TURN_DURATION + (random(8) - 2) * duration_increment : TURN_DURATION);
_forwardSpeed = speed;
if (speed == FullSpeed) full_speed_start_time = loop_start_time;
int getForwardSpeed()
int speed;
switch (_forwardSpeed)
case FullSpeed:
speed = FULL_SPEED;
break;
case SustainedSpeed:
speed = SUSTAINED_SPEED;
break;
default:
speed = SEARCH_SPEED;
break;
return speed;
// check for contact, but ignore readings immediately after turning or losing contact
bool check_for_contact()
static long threshold_squared = (long) XY_ACCELERATION_THRESHOLD * (long) XY_ACCELERATION_THRESHOLD;
return (lsm303.ss_xy_avg() > threshold_squared) && \
(loop_start_time - last_turn_time > MIN_DELAY_AFTER_TURN) && \
(loop_start_time - contact_made_time > MIN_DELAY_BETWEEN_CONTACTS);
// sound horn and accelerate on contact -- fight or flight
void on_contact_made()
#ifdef LOG_SERIAL
Serial.print("contact made");
Serial.println();
#endif
in_contact = true;
contact_made_time = loop_start_time;
setForwardSpeed(FullSpeed);
ledRed(1);
// reset forward speed
void on_contact_lost()
#ifdef LOG_SERIAL
Serial.print("contact lost");
Serial.println();
#endif
in_contact = false;
setForwardSpeed(SearchSpeed);
ledRed(0);
// class Accelerometer -- member function definitions
// enable accelerometer only
// to enable both accelerometer and magnetometer, call enableDefault() instead
void Accelerometer::enable(void)
// Enable Accelerometer
// 0x27 = 0b00100111
// Normal power mode, all axes enabled
writeAccReg(LSM303::CTRL_REG1_A, 0x27);
if (getDeviceType() == LSM303::device_DLHC)
writeAccReg(LSM303::CTRL_REG4_A, 0x08); // DLHC: enable high resolution mode
void Accelerometer::getLogHeader(void)
Serial.print("millis x y len dir | len_avg dir_avg | avg_len");
Serial.println();
void Accelerometer::readAcceleration(unsigned long timestamp)
readAcc();
if (a.x == last.x && a.y == last.y) return;
last.timestamp = timestamp;
last.x = a.x;
last.y = a.y;
ra_x.addValue(last.x);
ra_y.addValue(last.y);
#ifdef LOG_SERIAL
Serial.print(last.timestamp);
Serial.print(" ");
Serial.print(last.x);
Serial.print(" ");
Serial.print(last.y);
Serial.print(" ");
Serial.print(len_xy());
Serial.print(" ");
Serial.print(dir_xy());
Serial.print(" | ");
Serial.print(sqrt(static_cast<float>(ss_xy_avg())));
Serial.print(" ");
Serial.print(dir_xy_avg());
Serial.println();
#endif
float Accelerometer::len_xy() const
return sqrt(last.x*a.x + last.y*a.y);
float Accelerometer::dir_xy() const
return atan2(last.x, last.y) * 180.0 / M_PI;
int Accelerometer::x_avg(void) const
return ra_x.getAverage();
int Accelerometer::y_avg(void) const
return ra_y.getAverage();
long Accelerometer::ss_xy_avg(void) const
long x_avg_long = static_cast<long>(x_avg());
long y_avg_long = static_cast<long>(y_avg());
return x_avg_long*x_avg_long + y_avg_long*y_avg_long;
float Accelerometer::dir_xy_avg(void) const
return atan2(static_cast<float>(x_avg()), static_cast<float>(y_avg())) * 180.0 / M_PI;
// author: Rob.Tillart@gmail.com
// Released to the public domain
T RunningAverage<T>::zero = static_cast<T>(0);
RunningAverage<T>::RunningAverage(int n)
_size = n;
_ar = (T*) malloc(_size * sizeof(T));
clear();
RunningAverage<T>::~RunningAverage()
free(_ar);
// resets all counters
void RunningAverage<T>::clear()
_cnt = 0;
_idx = 0;
_sum = zero;
for (int i = 0; i< _size; i++) _ar[i] = zero; // needed to keep addValue simple
// adds a new value to the data-set
void RunningAverage<T>::addValue(T f)
_sum -= _ar[_idx];
_ar[_idx] = f;
_sum += _ar[_idx];
_idx++;
if (_idx == _size) _idx = 0; // faster than %
if (_cnt < _size) _cnt++;
// returns the average of the data-set added so far
T RunningAverage<T>::getAverage() const
if (_cnt == 0) return zero; // NaN ? math.h
return _sum / _cnt;
// fill the average with a value
// the param number determines how often value is added (weight)
// number should preferably be between 1 and size
void RunningAverage<T>::fillValue(T value, int number)
clear();
for (int i = 0; i < number; i++)
addValue(value);
First kindly request is that my robot is not next to me , it is forbidden to take out of office, Could someone load the program own zumo robot for me ? because the race will be on wednesday.
And second when i was soldering , i melted my motors encoder a bit and a blue led which is on behind left side, is always off position. Do they create a big fault?
Last, my robot wakes up 5,6 seconds ,pressed the A button later. Why?
