First off, I apologize for the post. I am sure this is very simple, but I spent all day looking through documentation and sample code and have not been able to successfully do what I want to.
I have two Wixels. One of them is connected to a device that sends data to one of the analog pins. This data can be simplified to either being 0 or 1. I want to relay this value, 0 or 1, to the other Wixel.
Basically, when the incoming data to Wixel A is 1, I light up the Yellow LED. When it is 0, I turn it off. I want the same behavior to occur on Wixel B, by sending the data from Wixel A to Wixel B.
The setup is wireless, so I believe I should be using UART to Radio to transmit the data. Unfortunately I can’t figure out how to package the data (a single bit really) and transmit/receive it. (I should note that I have been looking at the wireless serial sample app to accomplish this as I figured that was a good starting point).
Thank you for the help!
-Nick
