I am using a wixel to control a Futaba S3114 servo. I have the following code, based on the test_servos app, “working” but not as I would expect. It does move the servo from side to side through about 90 degrees.
However, there are 2 problems:
when I change the 2nd call to servoSetTarget(5, 1000) - or use any other target value - the servo still moves the same 90 degrees. I would expect it to not move at all with both calls to servoSetTarget set at 1000.
I wanted to use pins[1] or (P0_3) to trigger a cycle of the back and forth movement but when I short P0_3 to ground nothing happens. Experimenting a little I found that shorting pin P0_1 to ground caused a back and forth cycle of the servo.
What did I do wrong?
Thanks,
Burke
/** test_servos app:
* This app tests the servo library by using it to transmit servo pulses on
* all six available pins: P0_2, P0_3, P0_4, P1_2, P1_1, and P1_0.
* This is mainly intended for people who are changing the servo library. If
* you just want to use the library to control a servo from a Wixel, see the
* example_servo_sequence app.
#include <cc2511_map.h>
#include <servo.h>
#include <wixel.h>
#include <usb.h>
#include <usb_com.h>
// Here we define what pins we will be using for servos. Our choice is:
// Servo 0 = P0_2
// Servo 1 = P0_3
// Servo 2 = P0_4
// Servo 3 = P1_2
// Servo 4 = P1_1
// Servo 5 = P1_0
uint8 CODE pins[] = {2, 3, 4, 12, 11, 10};
uint8 bStrikeMagnet = 0;
uint32 ulStartTime = 0;
void myServosInit()
// Start the servo library.
servosStart((uint8 XDATA *)pins, sizeof(pins));
// Set the speed of servo
servoSetSpeed(5, 0); // Not actually necessary because default speed is 0 (no speed limit).
void updateServos()
if ((getMs() - ulStartTime) < 1000)
servoSetTarget(5, 1000);
LED_YELLOW(0);
else if ((getMs() - ulStartTime) >= 1000 && (getMs() - ulStartTime) < 2000)
LED_YELLOW(1);
else
bStrikeMagnet = 0;
// Takes care of receiving commands from the USB virtual COM port.
void receiveCommands()
if (usbComRxAvailable() == 0){ return; }
switch(usbComRxReceiveByte())
case 's': // Start/Stop
if (servosStarted())
servosStop();
else
servosStart(0, 0);
break;
void main()
systemInit();
usbInit();
myServosInit();
while(1)
boardService();
usbComService();
usbShowStatusWithGreenLed();
// if button is pushed then cycle servo back and forth once
if (!isPinHigh(1))
bStrikeMagnet = 1;
ulStartTime = getMs();
updateServos();
receiveCommands();
// The red LED will be on if any of the servos are moving.
LED_RED(servosMoving());
