I intend to build a robot rover controlled by an on-vehicle IBM-compatible PC (running windows or linux).
The PC is based around a VIA Mini-ITX motherboard, and powered by 12V battery. I intend to use Java to control the robot actions through PC serial port.
I am not yet very familiar with robots/electronics (being a high-level programmer), so I need some initial advice on architecture.
Will this setup work ?
|12V battery|
|to power PC|
|IBM PC|
|PC serial port|
|Pololu 8-Servo Controller|
|Pololu Dual Serial Motor Controller-1|
| |2 Gearmotors Tamiya 72004|
|4 NiMH 1.2V 2200 mAh in parallell |
Any advice or suggestions for changes/improvements would be very welcome!
