I own 3, 2-cell AA size liFeP04 battery packs 6.6 volts, 800 mah. They do not have a balance connector on them. I can’t seem to charge them, I keep getting a “Balance connect error” from my charger. Is it possible to charge LiFe batteries without a balance cable? If not is it possible to install a balance cable to a battery pack?
The iMAX Balance Charger and Discharger is intended to be used with lithium packs that come with built-in balance leads. It is possible to install your own balance cable, but we cannot help you with that. I recommend you get another battery pack with a balance connector.
- Amanda
