Greetings,
I’m a visual artist working on a project for which I’ll need 2 Geared DC Motors (assembled) & 2 Motor Controllers.
The Geared DC Motors will provide the power to turn the outermost gimbal of 2 gyroscopes.
The Motor Controllers will in turn be attached to the respective motors, thus allowing me to control the speed at which each gyroscope turns.
The diameter of the outermost gimbal of each gyroscope is 6 inches. Each gyroscope consists of 4 gimbals and are constructed of lightweight Basswood. The width of each gimbal is 1/2 inch. So the motors would have to be able to take some kind of load, however minimal.
I think I’d prefer a motor with a maximum rpm of up to 170 or somewhere close to this.
Which Geared DC Motor & Motor Controller would you recommend for the application described above given the specs indicated?
Please let me know if you require additional info. Thanks for time and consideration.
