I wonder is there something important missing from my attempts to flash a program with make flash using ft232. I have ubuntu 22.04 and Atmega328PB board which I can successfully flash using arduino ide but I’d like to use VS code instead.
This is my make flash output:
avrdude -v -c arduino -p m328pb -P /dev/ttyUSB0 -U flash:w:atmega328pb_test.hex
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/tuomas/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
AVR Part : ATmega328PB
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9516 (probably m328pb)
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "atmega328pb_test.hex"
avrdude: input file atmega328pb_test.hex auto detected as Intel Hex
avrdude: writing flash (0 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 0 bytes of flash written
avrdude: verifying flash memory against atmega328pb_test.hex:
avrdude: load data flash data from input file atmega328pb_test.hex:
avrdude: input file atmega328pb_test.hex contains 0 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 0 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
ft232 rx and tx leds flash like it is sending data but the code is not run on the 328pb. Here is also my makefile:
MCU = atmega328pb
F_CPU = 16000000UL
BAUD = 9600UL
## Also try BAUD = 19200 or 38400 if you're feeling lucky.
## A directory for common include files and the simple USART library.
## If you move either the current folder or the Library folder, you'll
## need to change this path to match.
LIBDIR = ../../AVR-Programming-Library
########## Programmer Defaults ##########
########## Set up once, then forget about it ##########
########## (Can override. See bottom of file.) ##########
PROGRAMMER_TYPE = arduino
# extra arguments to avrdude: baud rate, chip type, -F flag, etc.
PROGRAMMER_ARGS =
########## Program Locations ##########
########## Won't need to change if they're in your PATH ##########
CC = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
AVRSIZE = avr-size
AVRDUDE = avrdude
########## Makefile Magic! ##########
########## Summary: ##########
########## We want a .hex file ##########
########## Compile source files into .elf ##########
########## Convert .elf file into .hex ##########
########## You shouldn't need to edit below. ##########
## The name of your project (without the .c)
# TARGET = blinkLED
## Or name it automatically after the enclosing directory
TARGET = $(lastword $(subst /, ,$(CURDIR)))
# Object files: will find all .c/.h files in current directory
# and in LIBDIR. If you have any other (sub-)directories with code,
# you can add them in to SOURCES below in the wildcard statement.
SOURCES=$(wildcard *.c $(LIBDIR)/*.c)
OBJECTS=$(SOURCES:.c=.o)
HEADERS=$(SOURCES:.c=.h)
## Compilation options, type man avr-gcc if you're curious.
CPPFLAGS = -DF_CPU=$(F_CPU) -DBAUD=$(BAUD) -I. -I$(LIBDIR)
CFLAGS = -Os -g -std=gnu99 -Wall
## Use short (8-bit) data types
CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
## Splits up object files per function
CFLAGS += -ffunction-sections -fdata-sections
LDFLAGS = -Wl,-Map,$(TARGET).map -L/snap/arduino/85/hardware/tools/avr/avr/lib/avr5
LIBS = -latmega328pb
$(TARGET).elf: $(OBJECTS)
$(CC) $(LDFLAGS) $(TARGET_ARCH) $^ -o $@ $(LIBS)
all: $(TARGET).hex
clean:
rm -f $(TARGET).elf $(TARGET).hex $(OBJECTS) $(TARGET).map
$(TARGET).hex: $(TARGET).elf
$(OBJCOPY) -j .text -j .data -O ihex $< $@
.PHONY: all clean
# programmer for Pololu atmega 328pb is "arduino" and partno "m328p"
flash:
avrdude -v -c arduino -p m328pb -P /dev/ttyUSB0 -U flash:w:$(TARGET).hex
What am I missing?
Here’s also the small test application but I don’t think the flash is going through:
#include <avr/io.h>
#include <stdio.h>
#include <util/delay.h>
#define F_CPU 16000000UL // Set CPU frequency to 16MHz
#define BAUD 115200
#define UBRR_VALUE ((F_CPU/16/BAUD)-1)
void uart_init(void) {
// Set baud rate
UBRR0H = (uint8_t)(UBRR_VALUE >> 8);
UBRR0L = (uint8_t)UBRR_VALUE;
// Enable transmitter
UCSR0B = (1 << TXEN0);
// Set frame format: 8 data bits, no parity, 1 stop bit
UCSR0C = (1 << UCSZ01) | (1 << UCSZ00);
int uart_putchar(char c, FILE *stream) {
if (c == '\n') {
uart_putchar('\r', stream);
// Wait for transmit buffer to be empty
while (!(UCSR0A & (1 << UDRE0)));
// Write character to transmit buffer
UDR0 = c;
return 0;
FILE uart_output = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
int main(void)
// Initialize UART
uart_init();
// Redirect stdout to UART
stdout = &uart_output;
// Set PB5 as output
DDRB |= (1 << PB5);
while (1) {
// Toggle PB5
PORTB ^= (1 << PB5);
printf("LED state: %d\n", (PORTB >> PB5) & 1);
// Wait for 2 seconds
_delay_ms(1000);
return 0;
