Hello, if the S10V3F9 has been discontinued, are there other units that can output 9 volts DC from a higher voltage DC? This might be in the product description so my apologies if I missed it.
Thank you,
-Tom
Thank you,
-Tom
Hello, Tom.
You might consider the D36V6F9 or D24V10F9 for stepping a higher voltage down to 9V. They can both handle more current than the S10V3F9, so if the S10V3F9 was able to handle your load, they should be able to as well (and likely run cooler too).
Thanks Brandon! I got it all wired up and it works very well for powering 9 volt guitar pedals!
