Hello! I only want to use the proximity sensor data if the light sensor is in the dark, but my sensor always shows Ambient: 0 in the InterleavedContinuous.ino sketch regardless of the light. If there are more examples of taking readings from the light sensor?
I have the correct connection of 5 wires, the proximity sensor data goes well.
Hi.
Have you ever gotten non-zero ambient light readings from this sensor? Could you post pictures of the sensor and conditions in your testing setup? Pictures of the connections to double check would also be good.
-Claire
