Hey, JonathanKosh.
I have a startup issue with my vl6180x. whenever i try to read 0x018 register shows 0(HEX) value.Even if i’m writing 1(HEX) to 0x018. Then also it shows 0, am i missing some steps in initialization…
Thanks
Rahul
Hey, JonathanKosh.
Thanks
Rahul
Hello, Rahul.
I moved this post to a new topic since it does not appear to be related to the original post. It sounds like you are trying to set the SYSRANGE__START register. According to the VL6180X datasheet, that bit can be auto-cleared, so it should not be too surprising if it does not hold the value you set for it. If you tell me more about how you want the sensor to behave for your application, post your code, and tell me how the system is behaving, I might be able to help you find and solve a problem.
-Nathan
i am trying to run vl6180x explorer shield with arduino uno without using wire library
this is the code…
#define scl 19 // I2C bus
#define sda 18 //
#define gpio0 13
#define gpio1 12
int ack_flag;
unsigned char ack;
void setup() {
Serial.begin(9600);
pinMode(sda, OUTPUT);
pinMode(scl, OUTPUT);
pinMode(gpio0, OUTPUT);
pinMode(gpio1, INPUT);
// I2C Software Implementation
void i2c_start(void)
digitalWrite(sda, HIGH); // i2c start bit sequence
digitalWrite(scl, HIGH);
delayMicroseconds(100);
digitalWrite(sda, LOW);
digitalWrite(scl, LOW);
delayMicroseconds(1000);
void i2c_stop(void)
digitalWrite(sda, LOW); // i2c stop bit sequence
delayMicroseconds(100); //
delayMicroseconds(1000); //
unsigned char i2c_rx(unsigned char ack)
// digitalWrite(sda, HIGH);//*
pinMode(sda, INPUT_PULLUP);//*
char x, d = 0;
for (x = 0; x < 8; x++)
d <<= 1;
//pinMode(sda, INPUT_PULLUP);
if (digitalRead(sda)) {
d |= 0x01;
else {
d |= 0x00;
//d <<= 1;
if (ack) digitalWrite(sda, LOW);
else digitalWrite(sda, HIGH);
delayMicroseconds(10);
delayMicroseconds(100); // send (N)ACK bit
return d;
int i2c_tx(uint16_t d)
// Serial.print("d = ");
// Serial.println(d, HEX);
// delay(2000);
uint16_t x;
// digitalWrite(sda, LOW);
for (x = 0; x < 8; x++) {
if (d & 0x80) digitalWrite(sda, HIGH);
else digitalWrite(sda, LOW);
d <<= 1;
//digitalWrite(sda, HIGH);
ack = digitalRead(sda); // possible ACK bit
ack_flag = 0;
Serial.println ('N');
if (!(digitalRead(sda)))
ack_flag = 1;
Serial.println ('Y');
return ack;
// WriteByte Function
void WriteByte(uint16_t reg, uint16_t data) {
char data_write[2];
data_write[0] = (reg >> 8) & 0xFF;; // MSB of register address
data_write[1] = reg & 0xFF; // LSB of register address
ack_flag = 1;
i2c_start();
i2c_tx (0x52);
delay(100);
i2c_tx (data_write[0]);
delay(100);
i2c_tx (data_write[1]);
delay(100);
i2c_tx (data);
delay(100);
i2c_stop();
if (ack_flag == 1)
Serial.println ("WB ACK = YES");
Serial.print ("Reg_WB = ");
Serial.println (reg, HEX);
Serial.print ("Data_WB = ");
Serial.println (data, HEX);
if (ack_flag == 0)
Serial.print("WB ACK = NO");
// ReadByte Function
char ReadByte(int reg) {
char data_write[2];
char data_read[1];
uint16_t data_low;
uint16_t data_high;
data_write[0] = (reg >> 8) & 0xFF; // MSB of register address
ack_flag = 1;
i2c_start();
i2c_tx (0x52);
delay(100);
delay(100);
i2c_stop();
delay(100);
if (ack_flag == 1)
Serial.println ("RBT ACK = YES");
delay(100);
i2c_start();
i2c_tx (0x53);
delay(100);
data_read[0] = i2c_rx (1);
// data_high = i2c_rx (1);
// data_low = i2c_rx (0);
// uint16_t data = (data_high << 8) | data_low & 0xFF;
delay(100);
i2c_stop();
// return data;
return data_read[0];
Serial.print ("Reg_RB = ");
// Serial.print ("Data_RB = ");
// Serial.println (data, HEX);
Serial.print ("data_read[0]_RB = ");
Serial.println (data_read[0], HEX);
int VL6180X_Init()
// load settings
// Mandatory : private registers
WriteByte(0x0207, 0x01);
WriteByte(0x0208, 0x01);
WriteByte(0x0096, 0x00);
WriteByte(0x0097, 0xfd);
WriteByte(0x00e3, 0x00);
WriteByte(0x00e4, 0x04);
WriteByte(0x00e5, 0x02);
WriteByte(0x00e6, 0x01);
WriteByte(0x00e7, 0x03);
WriteByte(0x00f5, 0x02);
WriteByte(0x00d9, 0x05);
WriteByte(0x00db, 0xce);
WriteByte(0x00dc, 0x03);
WriteByte(0x00dd, 0xf8);
WriteByte(0x009f, 0x00);
WriteByte(0x00a3, 0x3c);
WriteByte(0x00b7, 0x00);
WriteByte(0x00bb, 0x3c);
WriteByte(0x00b2, 0x09);
WriteByte(0x00ca, 0x09);
WriteByte(0x0198, 0x01);
WriteByte(0x01b0, 0x17);
WriteByte(0x01ad, 0x00);
WriteByte(0x00ff, 0x05);
WriteByte(0x0100, 0x05);
WriteByte(0x0199, 0x05);
WriteByte(0x01a6, 0x1b);
WriteByte(0x01ac, 0x3e);
WriteByte(0x01a7, 0x1f);
WriteByte(0x0030, 0x00);
WriteByte(0x016, 0x00); //change fresh out of set status to 0
// Added latest settings here
// Recommended : Public registers - See data sheet for more detail
WriteByte(0x0011, 0x10);// Enables polling for ‘New Sample ready’ when measurement completes
WriteByte(0x010a, 0x30);// Set the averaging sample period (compromise between lower noise and increased execution time)
WriteByte(0x003f, 0x46);// Sets the light and dark gain (upper nibble). Dark gain should not be changed.
WriteByte(0x0031, 0xFF);// sets the # of range measurements after which auto calibration of system is performed
// WriteByte(0x0040, 0x63);//xxxxxxxdata_1 Set ALS integration time to 100ms
WriteByte(0x002e, 0x01); //xxxxxxxdata_0 perform a single temperature calibration of the ranging sensor
WriteByte(0x001b, 0x09); //Set default ranging inter-measurement period to 100ms
WriteByte(0x003e, 0x31); // Set default ALS inter-measurement period to 500ms
reg_data(0x003e);
WriteByte(0x0014, 0x24); // Configures interrupt on ‘New Sample Ready threshold event’
return 0;
// Start a range measurement in single shot mode
int VL6180X_Start_Range() {
WriteByte(0x018, 0x01);
char SYSRange_start = ReadByte(0x018);
delay (1000);
Serial.print("SYSRange_start = ");
Serial.println(SYSRange_start, HEX);
if (SYSRange_start == 0)
Serial.println("Start Range Measurement");
delay (1000);
else if (SYSRange_start == 2)
delay (1000);
else {
Serial.println("Device is Not Ready For Measurement");
delay (1000);
return 0;
// poll for new sample ready
int VL6180X_Poll_Range() {
char status;
char range_status;
// check the status
status = ReadByte(0x04f);
range_status = status & 0x07; // wait for new measurement ready status
while (range_status != 0x04) {
Serial.print("status = ");
Serial.println(status, HEX);
Serial.println("waiting");
Serial.print("range_status = ");
Serial.println(range_status, HEX);
delay(1000);
return 0;
// Read range result (mm)
int VL6180X_Read_Range() {
int range;
range = ReadByte(0x062);
Serial.print("Range = ");
Serial.println(range, HEX);
return range;
// clear interrupts
int VL6180X_Clear_Interrupts() {
WriteByte(0x015, 0x07);
return 0;
// Main
void loop() {
digitalWrite(gpio0, LOW);
delay (1);
start: digitalWrite(gpio0, HIGH);
// delayMicroseconds(10);
// digitalWrite(gpio1, HIGH);
delay (10);
WriteByte(0x016, 0x01);
delay (10);
char reset;
reset = ReadByte(0x016);
Serial.print("Reset = ");
Serial.println(reset, HEX);
if (reset == 1) {
Serial.println("Device is Ready");
delay (1000);
// WriteByte(0x0016, 0x00);
else {
Serial.println("Device is Busy");
delay (1);
goto start;
VL6180X_Init(); // load settings onto VL6180X
int range;
while (1) {
VL6180X_Start_Range(); // start single range measurement
VL6180X_Poll_Range(); // poll the VL6180X till new sample ready
range = VL6180X_Read_Range(); // read range result
VL6180X_Clear_Interrupts(); // clear the interrupt on VL6180X
Thanks
-Rahul
You might use a logic analyzer to verify your I2C communications are working as you intend. It looks like you are attempting to set all the same registers as our library and our library works, so it is not clear what the difference is.
-Nathan
