Hello There, I am trying to use the sensor to take 4 different readings and record then a 128x64 OLED, each reading is set by (switch case) 4 times where sensor is reading continuously and overwrite readings 2,3,4 which overlaps, ideally I would like to take a sample of 4 readings and average them in each class state, the display should hold each reading untill reser at the end of sketch.
I have been trying to get everything working for months now and still not quite there, I am a 76 year old trying to learn new tricks.
Your help getting the coding right eould be Greatly Appreciated.
Duggy
/* This example shows how to get single-shot range
measurements from the VL53L0X. The sensor can optionally be
configured with different ranging profiles, as described in
the VL53L0X API user manual, to get better performance for
a certain application. This code is based on the four
"SingleRanging" examples in the VL53L0X API.
The range readings are in units of mm. */
#include <Wire.h>
#include <VL53L0X.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <NewPing.h>
#define laser 3
#define button 6 // Pushbutton on D3
#define resetPin 7
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
VL53L0X sensor;
int state = 0; // integer to hold current state
int old = 0; // interger to hold last state
int buttonPoll = 0; // intereger to hold button state
// Uncomment this line to use long range mode. This
// increases the sensitivity of the sensor and extends its
// potential range, but increases the likelihood of getting
// an inaccurate reading because of reflections from objects
// other than the intended target. It works best in dark
// conditions.
//#define LONG_RANGE
// Uncomment ONE of these two lines to get
// - higher speed at the cost of lower accuracy OR
// - higher accuracy at the cost of lower speed
//#define HIGH_SPEED
#define HIGH_ACCURACY
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
void setup()
Serial.begin(115200);
Wire.begin();
digitalWrite(resetPin,HIGH);
pinMode(resetPin,OUTPUT);
pinMode(laser,OUTPUT);
digitalWrite(laser,LOW);
pinMode(button,INPUT); // button set as INPUT
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x32)
sensor.setTimeout(500);
if (!sensor.init())
Serial.println("Failed to detect and initialize sensor!");
while (1) {}
#if defined LONG_RANGE
// lower the return signal rate limit (default is 0.25 MCPS)
sensor.setSignalRateLimit(0.1);
// increase laser pulse periods (defaults are 14 and 10 PCLKs)
sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodPreRange, 18);
sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodFinalRange, 14);
#endif
//#if defined HIGH_SPEED
// reduce timing budget to 20 ms (default is about 33 ms)
//sensor.setMeasurementTimingBudget(20000);
//#elif defined HIGH_ACCURACY
// increase timing budget to 200 ms
//sensor.setMeasurementTimingBudget(200000);
//#endif
display.setTextSize(3);
display.setTextColor(WHITE);
display.clearDisplay();
display.setCursor(20,20);
display.print("READY");
display.display();
//Serial.print(sensor.readRangeSingleMillimeters());
void loop()
display.setTextSize(2);
if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
// De Bouncing routine to read button
buttonPoll = digitalRead(button); // Poll the state of the button
if (buttonPoll == 1){ // Chech to see if it has been pressed
delay(500); // wait 50 Ms
buttonPoll = digitalRead(button); //Poll button again
if (buttonPoll == 0){ // if it is 0 considered one press
//Serial.print("button press 1 ");
state = old + 1; // Increase state by 1
else{ // if button has not been pressed
delay (100); // Wait 100 ms
Serial.println();
switch(state) { // React to buttonPress and state
case 1: // If state is 1
Serial.println ("Case 1");
digitalWrite(laser,HIGH);
display.setCursor(0,0);
display.print("1 - ");
display.setCursor(40,0);
display.print(sensor.readRangeSingleMillimeters());
display.setCursor(95,0);
display.print("mm");
display.display();
delay(100);
old = state; // Set old state as current state
break;
case 2: // If state is 1
Serial.println ("Case 2");
//display.clearDisplay();
display.setCursor(0,16);
display.print("2 - ");
display.setCursor(40,16);
display.setCursor(95,16);
display.display();
break;
case 3: // If state is 1
Serial.println ("Case 3");
display.setCursor(0,34);
display.print("3 - ");
display.setCursor(40,34);
display.setCursor(95,34);
display.display();
break;
case 4: // If state is 1
Serial.println ("Case 4");
display.setCursor(0,52);
display.print("4 - ");
display.setCursor(40,52);
display.setCursor(95,52);
display.display();
break;
case 5: // If state is 1
Serial.println("Case 5");
display.setCursor(30,20);
display.print("RESET");
display.display();
delay(1000);
digitalWrite(resetPin,LOW);
delay(1000);
Serial.println ("END");
default: // if state is not 1,2,3,4
delay(1000);
// delay(5000);
