Hello Amanda, thanks for your fast answer! ![:slight_smile: :slight_smile:](https://forum.pololu.com/images/emoji/twitter/slight_smile.png?v=12)
I uploaded your example sketch without any WiFi or other things to the board and the error still appears.
After the following 3 tests it seems that it is really because of bad connection/soldering:
// TEST 1
[E][esp32-hal-i2c.c:1426] i2cCheckLineState(): Bus Invalid State, TwoWire() Can't init sda=1, scl=1
2069
2088
2097
2097
2099
2099
2093
2081
2096
2098
2079
2076
2094
2102
2102
2089
2089
2067
2075
2075
2094
2062
2067
1256
2191
2191
2073
2098
64351
2214
2214
2052
2062
2062
2070
2073
2082
2083
2064
2077
64351
2204
2195
2195
2089
2085
2085
2085
64351
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
0 TIMEOUT
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
64351
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
2085
// TEST 2
195
195
224
227
64351
442
230
230
230
225
229
224
231
64351
411
411
408
228
228
228
228
227
228
224
228
228
225
225
226
226
225
112
425
226
229
231
238
237
243
241
249
246
251
258
258
258
258
258
258
0 TIMEOUT
258
258
64351
258
258
258
64351
258
258
258
258
258
258
258
258
// TEST 3
[E][esp32-hal-i2c.c:1426] i2cCheckLineState(): Bus Invalid State, TwoWire() Can't init sda=0, scl=0
Failed to detect and initialize sensor!
Or do you think it still could be an issue with the ESP’s I2C? I also tried to lower the frequency to 100kHz, which doesn’t seem to make a difference.
Thanks again for your help!
