I am trying to use the Pololu library and example code to run 7 VL53L1X sensors on two different I2C busses (Wire1 & Wire2 on a Teensy 3.5).
I have tested all the sensors by themselves and in combinations, but I can’t get the final setup to work.
Here’s the code:
Created: 4/14/2023 4:55:00 PM
Author: FRANKNEWXPS15\Frank
This example shows how to set up and read multiple VL53L1X sensors connected to
the same I2C bus. Each sensor needs to have its XSHUT pin connected to a
different Arduino pin, and you should change sensorCount and the xshutPins array
below to match your setup.
For more information, see ST's application note AN4846 ("Using multiple VL53L0X
in a single design"). The principles described there apply to the VL53L1X as
well.
04/22/23 - this example was modified to connect three sensors (RF, RC, RR) to I2C Wire1, and
four sensors (LF, LC, LR & Rear) to I2C Wire2. This mimics the hardware arrangment
used on the actual robot.
#include <Wire.h>
#include <VL53L1X.h>
// The number of sensors in your system.
const uint8_t Wire1sensorCount = 3;
const uint8_t Wire2sensorCount = 4;
// The Arduino pin connected to the XSHUT pin of each sensor.
const uint8_t Wire1xshutPins[Wire1sensorCount] = {23,22,21};//04/14/23
const uint8_t Wire2xshutPins[Wire2sensorCount] = {5,6,7,8};//04/22/23
VL53L1X Wire1sensors[Wire1sensorCount];
VL53L1X Wire2sensors[Wire2sensorCount];
void setup()
while (!Serial) {}
Serial.begin(115200);
delay(2000); //04/14/23 needed for Teensy
Wire.begin();
Wire1.begin();
Wire2.begin();
//move some sensors to Wire1
for (uint8_t i = 0; i < Wire1sensorCount; i++)
//sensors[i].setBus(&Wire2);
Wire1sensors[i].setBus(&Wire1);
for (uint8_t i = 0; i < Wire2sensorCount; i++)
Wire2sensors[i].setBus(&Wire2);
// Disable/reset all sensors by driving their XSHUT pins low.
pinMode(Wire1xshutPins[i], OUTPUT);
digitalWrite(Wire1xshutPins[i], LOW);
Serial.printf("Set pin %d LOW\n", Wire1xshutPins[i]);
pinMode(Wire2xshutPins[i], OUTPUT);
digitalWrite(Wire2xshutPins[i], LOW);
Serial.printf("Set pin %d LOW\n", Wire2xshutPins[i]);
// Enable, initialize, and start each sensor, one by one.
// Stop driving this sensor's XSHUT low. This should allow the carrier
// board to pull it high. (We do NOT want to drive XSHUT high since it is
// not level shifted.) Then wait a bit for the sensor to start up.
//pinMode(xshutPins[i], INPUT);
pinMode(Wire1xshutPins[i], INPUT);
Serial.printf("Set pin %d to INPUT\n", Wire1xshutPins[i]);
delay(10);
Wire1sensors[i].setTimeout(500);
if (!Wire1sensors[i].init())
Serial.print("Failed to detect and initialize sensor ");
Serial.println(i);
while (1);
else
Serial.printf("init() succeeded for sensor %d\n", i);
// Each sensor must have its address changed to a unique value other than
// the default of 0x29 (except for the last one, which could be left at
// the default). To make it simple, we'll just count up from 0x2A.
Wire1sensors[i].setAddress(0x2A + i);
Serial.printf("sensor %d I2C address set to 0X%X\n",i, Wire1sensors[i].getAddress());
Wire1sensors[i].startContinuous(50);
pinMode(Wire2xshutPins[i], INPUT);
Serial.printf("Set pin %d to INPUT\n", Wire2xshutPins[i]);
delay(10);
Wire2sensors[i].setTimeout(500);
if (!Wire2sensors[i].init())
Serial.println(i);
while (1);
else
Wire2sensors[i].setAddress(0x2A + i);
Serial.printf("sensor %d I2C address set to 0X%X\n", i, Wire2sensors[i].getAddress());
Wire2sensors[i].startContinuous(50);
void loop()
Serial.printf("%lu\t", millis());
Serial.print(Wire1sensors[i].read());
if (Wire1sensors[i].timeoutOccurred()) { Serial.print(" TIMEOUT"); }
Serial.print('\t');
Serial.print(Wire2sensors[i].read());
if (Wire2sensors[i].timeoutOccurred()) { Serial.print(" TIMEOUT"); }
Serial.print('\t');
Serial.println();
And here is the output:
Port closed
Opening port
Port open
Set pin 23 LOW
Set pin 22 LOW
Set pin 21 LOW
Set pin 5 LOW
Set pin 6 LOW
Set pin 7 LOW
Set pin 8 LOW
Set pin 23 to INPUT
init() succeeded for sensor 0
sensor 0 I2C address set to 0X2A
Set pin 22 to INPUT
init() succeeded for sensor 1
sensor 1 I2C address set to 0X2B
Set pin 21 to INPUT
init() succeeded for sensor 2
sensor 2 I2C address set to 0X2C
Set pin 5 to INPUT
Set pin 6 to INPUT
Set pin 7 to INPUT
Set pin 8 to INPUT
init() succeeded for sensor 3
sensor 3 I2C address set to 0X2D
2588 266 251 172 0 TIMEOUT 694 723 831
3126 287 277 204 0 TIMEOUT 774 800 833
3645 286 277 205 0 TIMEOUT 763 791 831
4165 288 275 209 0 TIMEOUT 672 655 832
4685 287 278 211 0 TIMEOUT 570 584 836
5205 290 277 207 0 TIMEOUT 638 670 832
5725 286 278 208 0 TIMEOUT 660 682 832
6245 290 277 209 0 TIMEOUT 582 637 831
6765 287 276 207 0 TIMEOUT 560 614
As you can see, all 7 sensors were initialized properly, but only 6 respond with real distance values. The first sensor on Wire2 returns ‘0 TIMEOUT’.
Any ideas what I’m doing wrong here?
TIA,
Frank
