Hello!
I’m using two VL53LX1 sensors, each one conected to a different I2C port of TeensyLC, namely I2C(0) and I2C(1). So I have changed the Wire library for another one called i2c_t3. The later only runs on ARM, not AVR. I’m using the Arduino version of your library and Arduino IDE 1.8.9.
I have opened an issue on Github (Github - issue #6)
I’m asking for advice about the right manner of implementing this change. As far as I can tell, in other topics in this forum people is trying to run multiple sensors on the same bus, and I understand that using the XSHUT pin I can do that, so this is not my case.
Thank you in advance for your help.
