Good morning,
In my project i need to use two VL53L1X in order to count people walking trough two doors.
With your library (and example: ContinuesMultipleSensor) I’m able to use two sensor in full 16x16 SPAD.
I’m able also to configure just one sensor with two SPADS zones, and works.
But when I try to implement two sensors with two spads each, the sistem doesn’t work properly. It doesn’t seem to change zones as expected.
This is my code:
#include <SPI.h>
#include <Wire.h>
#include <VL53L1X.h>
const uint8_t sensorCount = 2; //numero sensori presenti
VL53L1X sensors[sensorCount]; //array dei sensori
const int xshutPins[sensorCount] = {3, 4}; //array dei pins xShut dei sensori
const int ROICenters[2] = { 167, 223 }; //centri delle 2 zone di ogni sensore
int distances[4]; //array contenente le misurazioni
void setup() {
pinMode(1, INPUT);
digitalWrite(1, HIGH);
while (!Serial) {}
Serial.begin(115200);
Wire.begin();
Wire.setClock(400000); // use 400 kHz I2C
// Disable/reset all sensors by driving their XSHUT pins low.
for (int i = 0; i < 2; i++) {
pinMode(xshutPins[i], OUTPUT);
digitalWrite(xshutPins[i], LOW);
// Enable, initialize, and start each sensor, one by one.
// Stop driving this sensor's XSHUT low. This should allow the carrier
// board to pull it high. (We do NOT want to drive XSHUT high since it is
// not level shifted.) Then wait a bit for the sensor to start up.
pinMode(xshutPins[i], INPUT);
delay(10);
sensors[i].setTimeout(500);
if (!sensors[i].init()) {
Serial.print("...ERROR failed to detect and initialize sensor ");
Serial.print(i);
Serial.println(" !");
while (1);
// Each sensor must have its address changed to a unique value other than
// the default of 0x29 (except for the last one, which could be left at
// the default). To make it simple, we'll just count up from 0x2A.
sensors[i].setAddress(0x2A + i);
Serial.println(sensors[i].getAddress());
sensors[i].setDistanceMode(VL53L1X::Long); // Measuring mode (Long, Medium, Short)
sensors[i].setMeasurementTimingBudget(50000); // Timing budget in us (microseconds) (min 33000 in Long mode)
sensors[i].setROISize(8,16); // Dimensione della zona del sensore
sensors[i].startContinuous(50); // Start continuous readings at a rate of one measurement every 50 ms (must be at least as long as timebudget)
delay(2000);
void loop() {
static int stV1; // stato del varco porta 1
static int stV2; // stato del varco porta 1
static int distdisplay[4];
sensors[0].setROICenter(ROICenters[i]);
distances[0+i] = sensors[0].read();
sensors[1].setROICenter(ROICenters[i]);
distances[2+i] = sensors[1].read();
Serial.print (distances[0]);
Serial.print (" : ");
Serial.print (distances[1]);
Serial.print (" -- ");
Serial.print (distances[2]);
Serial.println (distances[3]);
If I comment a “for cicle” of a sensor, the other works as expected.
Thanks for any help
