Hello, I am working on the VL53L1X sensor and I have programmed the ROI as 4x4. The device measurement I have noticed are not very accurate , so i decided to add an offset value to it. I saw the functions GetOffsetInMm, CalibrateOffset, SetOffset , but am not sure after which part to add it in programming or the order of these functions itself.
1.Does these functions work when continuous data is coming in or should I let it calculate for a short period of time and then let it decide the offset so I can take note of it and use it later.
2. I noticed that the error increases with distance, should I add different offset for different distance.
3. I have a sensor sending in measurement at 100ms and displaying in the serial monitor, do I apply the functions after reading the measurement or before
4.If I get the offset value should I have to add it to the measured value every time I display it in the serial monitor or does it perform the calculations for every measurement.
Thank you so much in advance.
Good day
