Hi, I bought 3 VL53L1X ToF, to use them as “gate sensors”, in a project of an automatic timewatch for sport ( 3 gates to measure 2 split times).
I started to interface the sensor with an Arduino microcontroller, usin I2C (everything ok), but now I’d like to use the VL53L1X as a “digital sensor”, having high level on interrupt (GPIO) pin when the measured distance is between a certain range (eg: 1.7 - 2.3 m), low level if the distance is outside the same range, and directly connect this digital output pin with a pin on a X-bee radio tranceiver.
Can you help me? How can I enable (if it’s possible) the GPIO pin and control the distance range?
Thank you, regards
Fabrizio
