I am planning to use the VL53L1X board to map out the surface profile of a workpiece prior to machining with a X Y Z CNC router. Depths from 1mm to 2mm must be milled off the surface of the workpiece, to an accuracy of +/-0.1mm, but the workpiece depth is irregular (it varies by up to 1mm). Therefore the Z axis depth varies across the entire surface in order to remove an exact amount. The color of the workpieces also varies. However, from what I read, VL53L1X is repeatable enough for a given set of lighting / object conditions. Therefore this is my plan to produce a depth map for creating the required G code.
a) install the VL53L1X on the Z axis.
b) place the workpiece on the CNC table
c) perform an initial calibration (to account for lighting, workpiece color, etc) - vary the Z axis height and plot this against the VL53L1X output. Having at least one absolute measurement would be helpful.
d) park the Z axis in the best position for accuracy.
e) build the depth map by moving X and Y across the workpiece and measuring the depth. Calculate true depth using the table derived in step c
Can you comment on the suitability of this design?
Moderators, I might have posted this in the wrong area, please shift if appropriate.
Thanks in advance.
