i trying to run the VL53L0x Sensor quickly. i start a new reading every 25ms and have a timing budget of 20ms so there is about 5ms to get and read the result via interrupt. I am using the pololu arduino library.
I initialise the sensor via the following.
Wire.begin();
sensor_j8.init();
sensor_j8.setTimeout(0);
sensor_j8.setMeasurementTimingBudget(20000);
u8_j8_stop_variable = sensor_j8.readReg(0x91);
sensor_j8.writeReg(0x80, 0x01);
sensor_j8.writeReg(0xFF, 0x01);
sensor_j8.writeReg(0x00, 0x00);
sensor_j8.writeReg(0x91, u8_j8_stop_variable);
sensor_j8.writeReg(0x00, 0x01);
sensor_j8.writeReg(0xFF, 0x00);
sensor_j8.writeReg(0x80, 0x00);
I then start off a reading of the senor with the following.
sensor_j8.writeReg(SYSRANGE_START, 0x01); //Start Reading
once the interrupt has triggered i get the result and clear the interrupt
data->u16_range_reading = sensor_j8.readReg16Bit(0x14 + 10);
sensor_j8.writeReg(SYSTEM_INTERRUPT_CLEAR,0x01);
once the time period has 25ms i then restart another reading with
etc… etc…
This all worked fine until with readings with a close background, but when i point the sensor into clear space i get readings of 8190/8191. Once those values have been returned it breaks my timing sequence. After doing some research they seem to map to error codes ? Do i need to do some additional in the software? Any information on these would be greatly appreciated.
To clarify when i get a result such as 8190/8191 it sometimes won’t trigger an interrupt on the GPIO1 pin. which as result throws of my timings.
Thanks in advance
Ali
