Hello!
I am using VL53L0X sensor for tracking in robot. I am using it in long range mode (33ms) but it is not working for distance greater than 1.2m.
If you have any info regarding this, kindly share.
Thanks.
I split your post off into a new thread, which seemed more appropriate.
Can you tell me more about your setup? It sounds like you are running the Single.ino example sketch from our VL53L0X Arduino library. Is that right? Which Arduino are you using? How are you supplying power? Can you tell me more about what material you are trying to sense and post pictures or a link to a video that shows your setup?
-Jon
