Verification error, first mismatch at byte 0x0000 0x62 != 0x0c
I am using an A-star 328PB 5V 20 MHz I am trying to upload Blink with Arduino IDE 1.8.13 via the TTL port of the Pololu USB AVR Programmer v2.1.
I get the following error: avrdude: verifying …
avrdude: verification error, first mismatch at byte 0x0000
0x62 != 0x0c
avrdude: verification error; content mismatch
When I try to butn the bootloader via the programming port from the Arduino IDE with the Atmel STK500 development board I get the following error avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
and the Polol USB AVR Programmer v2 Configuration Utility is like this:
What can I try?
Thanks!
Can you verify the bootloader is present on your A-Star 328PB Micro board (if you have not already done so)? The instructions for checking the serial bootloader are under the A-Star 328PB Serial Bootloader section of the Pololu A-Star 328PB user’s guide.
Can you post pictures clearly showing the soldering joints on your A-Star Micro board and how everything is connected in your setup when using the Pololu USB AVR Programmer’s serial header? Also, can you post a screenshot of your Arduino IDE with the Tools menu open, showing the board and port settings?
- Amanda
Hi Amanda,
I can confirm that the bottloader is present (led flashing after pressing the reset button).
I had a suspicion on the setup as well so I have desoldered it and uploaded Blink again. Nevertheless I got the same error.
Here is the setup on the Arduino IDE:
Configuration
Port 10 is the TTL port.
Thanks for providing those pictures and screenshot. Your soldering, connections, and settings in the Arduino IDE look fine.
Can you turn on verbose output and post the entire output after trying to program the A-Star? In case you do not know and for others following this thread, you can turn on verbose output by selecting “Preferences” from the “File” menu in the Arduino IDE and then checking the “compilation” and “upload” boxes next to “Show verbose output during:”. Also, when you try to program the A-Star can you make sure to plug the AVR programmer directly to your computer, not through a hub?
- Amanda
Hi Amanda,
here is the massage regarding compilation of Blink
\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\arduino-builder -dump-prefs -logger=machine -hardware \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\hardware -hardware \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages -tools \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\tools-builder -tools \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr -tools \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages -built-in-libraries \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\libraries -libraries \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\sketchbook\libraries -fqbn=pololu-a-star:avr:a-star328PB:version=20mhz,i2c=twi0,spi=spi0 -vid-pid=1FFB_00BB -ide-version=10813 -build-path C:\Users\Name\AppData\Local\Temp\arduino_build_590658 -warnings=none -build-cache C:\Users\Name\AppData\Local\Temp\arduino_cache_313804 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\examples\01.Basics\Blink\Blink.ino
\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\arduino-builder -compile -logger=machine -hardware \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\hardware -hardware \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages -tools \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\tools-builder -tools \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr -tools \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages -built-in-libraries \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\libraries -libraries \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\sketchbook\libraries -fqbn=pololu-a-star:avr:a-star328PB:version=20mhz,i2c=twi0,spi=spi0 -vid-pid=1FFB_00BB -ide-version=10813 -build-path C:\Users\Name\AppData\Local\Temp\arduino_build_590658 -warnings=none -build-cache C:\Users\Name\AppData\Local\Temp\arduino_cache_313804 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\examples\01.Basics\Blink\Blink.ino
Using board 'a-star328PB' from platform in folder: \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\pololu-a-star\hardware\avr\5.1.0
Using core 'arduino' from platform in folder: \\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\hardware\arduino\avr
Detecting libraries used...
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\sketch\\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sto compilando lo sketch...
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_pulse.S.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_analog.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\WInterrupts.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\hooks.c" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\hooks.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\wiring.c" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_digital.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_pulse.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_shift.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial1.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\CDC.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial0.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial3.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\PluggableUSB.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\IPAddress.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial2.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\Print.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\Print.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\Stream.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\Tone.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\USBCore.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\WMath.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\abi.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\abi.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\main.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\main.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\WString.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\WString.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino" "-I\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\hardware\\arduino\\avr\\cores\\arduino\\new.cpp" -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\new.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_pulse.S.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\WInterrupts.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\hooks.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_analog.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_digital.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_pulse.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\wiring_shift.c.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\CDC.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial0.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial1.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial2.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\HardwareSerial3.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\IPAddress.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\PluggableUSB.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\Print.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\Stream.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\Tone.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\USBCore.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\WMath.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\WString.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\abi.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\main.cpp.o"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\core.a" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\core\\new.cpp.o"
Archivio il core (caching) compilato in: C:\Users\Name\AppData\Local\Temp\arduino_cache_313804\core\core_742fc42fa076e1063cd8b7bdbc6c845f.a
Linking everything together...
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328pb -o "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658/Blink.ino.elf" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658\\sketch\\Blink.ino.cpp.o" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658/core\\core.a" "-LC:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658" -lm
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658/Blink.ino.elf" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658/Blink.ino.eep"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658/Blink.ino.elf" "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658/Blink.ino.hex"
"\\\[redacted]\\Arduino portable\\arduino-1.8.13-windows\\arduino-1.8.13\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Name\\AppData\\Local\\Temp\\arduino_build_590658/Blink.ino.elf"
Lo sketch usa 1184 byte (3%) dello spazio disponibile per i programmi. Il massimo è 32256 byte.
Le variabili globali usano 9 byte (0%) di memoria dinamica, lasciando altri 2039 byte liberi per le variabili locali. Il massimo è 2048 byte.
\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -C\\[redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328pb -carduino -PCOM10 -b115200 -D -Uflash:w:C:\Users\Name\AppData\Local\Temp\arduino_build_590658/Blink.ino.hex:i
Here is the message regarding the upload:
avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "[Redacted]\Arduino portable\arduino-1.8.13-windows\arduino-1.8.13\portable\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM10
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328PB
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9516 (probably m328pb)
avrdude: reading input file "C:\Users\Name\AppData\Local\Temp\arduino_build_590658/Blink.ino.hex"
avrdude: writing flash (1184 bytes):
Writing | ################################################## | 100% 0.13s
avrdude: 1184 bytes of flash written
avrdude: verifying flash memory against C:\Users\Name\AppData\Local\Temp\arduino_build_590658/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Name\AppData\Local\Temp\arduino_build_590658/Blink.ino.hex:
avrdude: input file C:\Users\Name\AppData\Local\Temp\arduino_build_590658/Blink.ino.hex contains 1184 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.13s
avrdude: verifying ...
         0x62 != 0x0c
avrdude done.  Thank you.
La porta seriale selezionata
 non esiste o la scheda non è connessa
Last mesagge is quite odd to me because it means: “The selected serial port does not exist or your board is not connected”.
I am connected directly to the PC. This also happens on another PC station.
If you need translation for other messages not in english please let me know.
Your AVRDUDE command looks good as well. We are still unsure what might be causing the issue. For now can you update your Arduino IDE to the latest version (2.0.3) and try programming the A-Star 328PB Micro again?
- Amanda
Tried on another PC because I cannot update to the version 2.0.3 due to an error of Arduino IDE 2.0.0.
Anyway I tried with Arduino IDE 2.0.3
It does not give any error but I do not see the LED blinking (I know the LED works because it flashes when I press the reset button).
Using board 'a-star328PB' from platform in folder: C:\[...]\AppData\Local\Arduino15\packages\pololu-a-star\hardware\avr\5.1.0
Using core 'arduino' from platform in folder: C:\[...]\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
"C:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10607 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-IC:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\[...]\AppData\\Local\\Arduino15\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236\\sketch\\Blink.ino.cpp" -o nul
"C:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10607 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-IC:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\[...]\AppData\\Local\\Arduino15\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236\\sketch\\Blink.ino.cpp" -o "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\[...]\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=20000000L -DARDUINO=10607 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 "-IC:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\[...]\AppData\\Local\\Arduino15\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\variants\\a-star328pb" "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236\\sketch\\Blink.ino.cpp" -o "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236\\sketch\\Blink.ino.cpp.o"
Compiling core...
Using precompiled core: C:\[...]\AppData\Local\Temp\arduino-core-cache\core_25fb4f47a0b863ec8b30ae998a39a321.a
"C:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328pb -o "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/Blink.ino.elf" "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236\\sketch\\Blink.ino.cpp.o" "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/..\\arduino-core-cache\\core_25fb4f47a0b863ec8b30ae998a39a321.a" "-LC:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236" -lm
"C:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/Blink.ino.elf" "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/Blink.ino.eep"
"C:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/Blink.ino.elf" "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/Blink.ino.hex"
"C:\[...]\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\[...]\AppData\\Local\\Temp\\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/Blink.ino.elf"
Sketch uses 1184 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\[...]\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\[...]\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328pb -carduino "-PCOM18" -b115200 -D "-Uflash:w:C:\[...]\AppData\Local\Temp\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/Blink.ino.hex:i"
         System wide configuration file is "C:\[...]\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM18
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         SCK period      : 3.3 us
avrdude: reading input file "C:\[...]\AppData\Local\Temp\arduino-sketch-B9180B4B9DF895EAA013FC7A7374E236/Blink.ino.hex"
Writing | ################################################## | 100% 0.15s
Can you post your Blink sketch and HEX files so that we can try to replicate your setup and issue here?
Also, can you power the A-Star from a different power source, not through the AVR programmer, and try burning the bootloader and uploading the Arduino’s Blink sketch again? If the attempt was unsuccessful, please post the output, screenshots, and pictures showing your settings and connections and any other relevant details.
- Amanda
