Dear community,
Hope you all are safe and sound.
I am considering using the " Pololu G2 High-Power Motor Driver 18v17" product to produce a high-power AC signal (<10 Hz) to connect an inductive coil and generate an alternating magnetic field.
As such, I am wondering if this board can address my requirement by setting the pins in the following configuration:
PIN: PWM- set always high (say +20V to have an output of 20V)
PIN: DIR: provide +10 and -10V AC input to toggle high and low for OUTA and OUTB, respectively.
I would be happy to receive your comments. Also, Plz suggest to me if there are any better options!
Best regards,
