Using 20 D gear, motors in underwater housing
I need to put a 20D gear motor into a waterproof housing. This requires putting a seal around the shaft where it exits the waterproof housing. Obviously the shaft has to be circular for the seal. Do you have D shafts that have a longer circular section close to the motor that would be good for this application?
