Can I use an external AVRISP mkII programmer with the SVP-1284?
I’m having intermittent programming issues using the built-in programmer on the SVP-1284.
I will start a separate thread to explain the symptoms and there are a few more things I need to try (such as removing all my Sharp IR range sensor to rule out noice on the 5V supply line). Basically, it takes 4-5 attempts to get a successfull programming cycle. Usually it stops somewhere in between. I tried avrdude, AVR Studio 4 and Atmel Studio 6. My SVP-1284 is running the 1.03 bootloader firmware.
I’m hoping that I can get to and eliminate the root cause of my issue, but until then, I still want to be able to program my SVP-1284, hence this question.
Chris.
