I have a A-star 328PB I am attempting to use with a Atmel JTAGICE3 emulator. I have the 6-pin vertical “ISP/debugWIRE” header on the A-star board connected to the emulator. However, using Microchip Studio, when I attempt to debug, I get a message saying that the DWEN fuse is not enabled, and do I want to use SPI to enable it. If I click yes, I get an error message saying “Failed to enable DW”. Also, I noticed there is a 0.1uF cap on the reset line of this interface on the A-star board, which Atmel/Microchip recommend against. Am I to infer that I cannot connect to this board using a JTAGICE3 (or presumably the later Atmel-ICE)?
EDIT: Found another post where someone talks about using the JTAGICE w/ the Orangutan board with an AVR Dragon and Jan from Pololu recommended removing that cap. The cap is C6; just not sure where it’s located on the A-star board and can’t seem to find a layout.
