Hey,
i’ve a problem with the Usccmd.exe. I’ll try to set a Output Channel “Enabled”.
In my case i’ve got a relais on Channel7. I tried this command:
UscCmd.exe --servo 7,1600
Setting target of servo 7 to 1600...
(1500 is the switching target)
In the Maestro Center Control the relais is switching, but when i use usccmd nothing happend :(.
Is there any examplecode to set enabled status on a channel? can’t find documentation or something else.
best regards and maybe thanks for help
joerg
