Hi, I just ordered a Pololu USB to Serial Adapter (item# 391) for a robotics project I’m working on. Unfortunately the board doesn’t have any mounting holes and I need some advice on how to mount the board. This adapter will go inside a large pelican watertight case with an aluminum front panel. I’d like to mount it somehow on the front panel. The simplest that comes to mind is to just use two sided foam tape or a couple pieces of velcro, but I’d prefer using a more secure mount than that. Any ideas?
If you’re not using all of the electrical pins, you could use some of those pads/holes for more secure mounting. Just be careful not to short them out!
- Jan
