USB driver for Zumo does not work in Windows 10
I bought the Zumo 32U4 a while ago. It did already work in the past with Windows 7. Now after a while I tried to install the driver (a-star-2.0.0) in Windows 10 Version 1703. Windows replied everything okay but the driver doesn’t appear in the device manager of Windows and the port isn’t shown in the Arduino IDE.
Any suggestion?
Can you try using a different USB cable (one that you know is working) if you have not already done so? Some USB cables (e.g. cell phone charging cables) are power-only cables and do not have the data lines.
If changing the USB cable does not fix the issue, can you select the “Device by connection” option under the “View” menu in the Device Manager, expand all of the “USB host controller” entries, and post a screenshot of it here?
- Amanda
Oh my god. I can’t believe it. I didn’t know about these differences and really used the cable from my new power bank that was lying around. Excuse me for wasting your time.
Wow, only after trying 13 different USB Micro B cables did I find 2 (two!) that fixed the problem!!
The included white cable did NOT work, it only supplied power
I can see the recognized robot as Pololu A-Star 32U4 as COM4
Good thing I am an organized pack-rat…
I am glad you were able to get your robots recognized! Unfortunately, a lot of USB cables are only intended for charging and leave out the extra wires required for data communication to save on cost.
By the way, please note that our Zumo robots do not come with a USB cable included. All of the USB cables we carry separately are data cables, so if you are using one you got from us directly, it should work for data communication.
