I have compiled the serial2 example provided in the libpololu-avr package on my SVP-1284P but I cannot get it to transmit bytes as the program descriptions mention.
I am using the OSX10.8 Terminal and tried echo G>/dev/tty.usbmodem00026041
, I know something is working because the green LED next to the USB port on the SVP flashes when I make the call but Terminal doesn’t seem to execute the command and I must exit the call manually.
What are the correct commands for communicating via the USB_COMM port using Terminal? Are there more examples for using the serial interface? Ultimately, I hope to communicate with a UART Bluetooth module which will transmit data gathered by the SVP to a Java program running on my laptop.
Thank you in advance for your help!
For reference, here is Serial2
[code]#include <pololu/orangutan.h>
- serial2: for the Orangutan SVP and Orangutan X2 controllers.
- This example listens for serial bytes transmitted via USB to the controller’s
- virtual COM port (USB_COMM). Whenever it receives a byte, it performs a
- custom action. Whenever the user presses the middle button, it transmits a
- greeting to the virtual COM port.
- This example will not work on the Orangutan LV, SV, Baby Orangutan, or 3pi robot.
- https://www.pololu.com/docs/0J20
https://forum.pololu.com
// receive_buffer: A ring buffer that we will use to receive bytes on USB_COMM.
// The OrangutanSerial library will put received bytes in to
// the buffer starting at the beginning (receiveBuffer[0]).
// After the buffer has been filled, the library will automatically
// start over at the beginning.
char receive_buffer[32];
// receive_buffer_position: This variable will keep track of which bytes in the receive buffer
// we have already processed. It is the offset (0-31) of the next byte
// in the buffer to process.
unsigned char receive_buffer_position = 0;
// send_buffer: A buffer for sending bytes on USB_COMM.
char send_buffer[32];
// wait_for_sending_to_finish: Waits for the bytes in the send buffer to
// finish transmitting on USB_COMM. We must call this before modifying
// send_buffer or trying to send more bytes, because otherwise we could
// corrupt an existing transmission.
void wait_for_sending_to_finish()
while(!serial_send_buffer_empty(USB_COMM))
serial_check(); // USB_COMM port is always in SERIAL_CHECK mode
// process_received_byte: Responds to a byte that has been received on
// USB_COMM. If you are writing your own serial program, you can
// replace all the code in this function with your own custom behaviors.
void process_received_byte(char byte)
clear(); // clear LCD
print("RX: ");
print_character(byte);
lcd_goto_xy(0, 1); // go to start of second LCD row
switch(byte)
// If the character 'G' or 'g' is received, toggle the green LED.
case 'G':
case 'g':
green_led(TOGGLE);
print("green LED");
break;
// If the character 'R' or 'r' is received, toggle the red LED.
case 'R':
case 'r':
red_led(TOGGLE);
print("red LED");
break;
// If the character 'C' or 'c' is received, play the note C.
case 'C':
case 'c':
play_from_program_space(PSTR("c16"));
print("play note C");
break;
// If the character 'D' or 'd' is received, play the note D.
case 'D':
case 'd':
play_from_program_space(PSTR("d16"));
print("play note D");
break;
// If any other character is received, change its capitalization and
// send it back.
default:
wait_for_sending_to_finish();
send_buffer[0] = byte ^ 0x20;
serial_send(USB_COMM, send_buffer, 1);
print("TX: ");
print_character(send_buffer[0]);
break;
void check_for_new_bytes_received()
while(serial_get_received_bytes(USB_COMM) != receive_buffer_position)
// Process the new byte that has just been received.
process_received_byte(receive_buffer[receive_buffer_position]);
// Increment receive_buffer_position, but wrap around when it gets to
// the end of the buffer.
if (receive_buffer_position == sizeof(receive_buffer)-1)
else
receive_buffer_position++;
int main()
clear(); // clear the LCD
print(“Send serial”);
print(“or press B”);
// Set the baud rate to 9600 bits per second. Each byte takes ten bit
// times, so you can get at most 960 bytes per second at this speed.
serial_set_baud_rate(USB_COMM, 9600);
// Start receiving bytes in the ring buffer.
serial_receive_ring(USB_COMM, receive_buffer, sizeof(receive_buffer));
while(1)
// USB_COMM is always in SERIAL_CHECK mode, so we need to call this
// function often to make sure serial receptions and transmissions
// occur.
serial_check();
// Deal with any new bytes received.
check_for_new_bytes_received();
// If the user presses the middle button, send "Hi there!"
// and wait until the user releases the button.
if (button_is_pressed(MIDDLE_BUTTON))
memcpy_P(send_buffer, PSTR("Hi there!\r\n"), 11);
serial_send(USB_COMM, send_buffer, 11);
send_buffer[11] = 0; // terminate the string
print("TX: ");
print(send_buffer);
// Wait for the user to release the button. While the processor is
// waiting, the OrangutanSerial library will not be able to receive
// bytes from the USB_COMM port since this requires calls to the
// serial_check() function, which could cause serial bytes to be
// lost. It will also not be able to send any bytes, so the bytes
// bytes we just queued for transmission will not be sent until
// after the following blocking function exits once the button is
// released. If any of this is a concern, you can replace the
// following line with:
// do
// while (button_is_pressed(MIDDLE_BUTTON))
// serial_check(); // receive and transmit as needed
// delay_ms(10); // debounce the button press/release
// while (button_is_pressed(MIDDLE_BUTTON));
wait_for_button_release(MIDDLE_BUTTON);
}[/code]
