Is there Pololu USB 16servo controller driver for MS Mobile 6.0?
We don’t really know anything about drivers or development for Windows Mobile. The 16 servo controller uses the CP2102 USB-to-serial bridge, so we don’t have much control of the drivers, too. You could do a more general search by seeing if anyone has used that chip with your platform. Alternatively, if you know of any USB-to-serial adapter that works, you could use that with a simple serial version of the servo controller.
- Jan
I have followed the Silicon Lab instructions in below but still failed. Simply no response from my mobile and not lights from Servo controller.
WinCE 6.0 USBXpress Driver 1.3.1
Copyright © 2008 Silicon Laboratories, Inc.
Hardware Support
- CP210x
- C8051F32x/F34x
Platform Support
- ARMV4I
- MIPSII
- MIPSII_FP
- MIPSIV
- MIPSIV_FP
- SH4
- x86
Files Included
SIUSBXP.DLL (Driver DLL)
SIUSBXP.REG (Registry Entry for SIUSBXP Driver)
SIUSBXP_LIB.DLL (API Interface DLL)
SIUSBXP_LIB.LIB (LIB file for API Interface DLL)
SIUSBXP_LIB.EXP (EXP file for API Interface DLL)
SIUSBXP_LIB.H (Header for the functions available in the API Interface DLL)
CP210xWinCETest.exe (Test app - Loopback)
CP210xWinCETest Source Code
CP210xWinCEtoWindowsHTTest.exe (Test App - Loopback/Null Modem to HyperTerminal)
CP210xWinCEtoWindowsHTTest Source Code
Release Dates
USBXpress for WinCE 1.3.1 - August 7, 2008
Installation Instructions
Copy the SIUSBXP.DLL and SIUSBXP.REG files the the \Windows directory on
the CE device. -
Plug in the CP210x Device with VID 10C4 and PID EA61. If your cP210x still contains the
default VID and PID (10C4, EA60) use the CP210xSetIDs.exe application in located
in Application Note to change the PID to EA61. AN144 and its software package (AN144SW) are
available here: -
When the dialog pops up saying “Unidentified USB Device” enter SIUSBXP for
the driver name. The dialog should close when OK is pressed, and the LED on
the CP210x development board should be lit. (If the dialog doesn’t pop up, but
the LED on the CP210x development board is on, then it automatically found the
device) -
The two included test applications can now be run (CP210xWinCETest.exe and
CP210xWinCEtoWindowsHTTest.exe) using the CP210x in loopback mode. To put the
device in a loopback state, disconnect the two jumpers for TXD and RXD, and reconnect
one jumper joining the TXD and RXD pins closest to the USB port - see Figure 1. Under
Normal Operation, running CP210xWinCEtoWindowsHTTest.exe will write to HyperTerminal
when hooked up via a Null Modem Cable.Figure 1: Serial Serial
T R D D D C R T R D D D C R
X X T R C S T T X X T R C S T T
D D R I D R S S D D R I D R S S
J2 | | | | | | | | J2 | | | | | |
. . . . . . . . .. . . . . . .USB USB
Normal Operation Loopback Mode
(Use w/WinCEtoWindowsHTTest.exe) (Use w/WinCETest.exe)
Release History
Release 1.3.1
- Modified the SIUSBXP driver to work properly with ARM devices
Release 1.3
- Added SI_SetBreak function for CP210x devices
- Modified to allow proper access of devices using SI_GetNumDevices with SI_Open/Close
Release 1.2
- Added SI_GetProductString function
Release 1.0
- Initial Release
Did you change the VID and PID? The servo controller ships with the PID set to a number Silicon Labs allocated for us, so you’ll first need to install the device with the driver we provide; you should then be able to use their set IDs application to set the IDs appropriately.
- Jan
I have tested the USB 16Servo with my C# apps on my XP and it was O.K.
After I changed the PID to EA61, Mobile still had no dialog pop up after the device had been plugged in.
Even the XP apps failed to run after that.
Once you change the PID, you have to reinstall the device with drivers from Silicon Labs; did you do that?
- Jan
