|SOLVED|“upgrade firmware” pgm file needed for micro maestro servo controller after i clicked and it didnt download the file ,new unit quit working. Pololu-1350 Micro Maestro 6-Channel USB Servo Controller Thnx |UPGRADE DONE|
It sounds like you solved the problem you were having. Were you able to get it working by retrying the firmware update with the version 1.04 firmware for the Micro Maestro 6-Channel USB Servo Controller (usc02a)?
