update I2C target address embedded in EEPROM
I was wondering if someone could show me the way to change I2C target address of the product, ACS37800KMACTR-030B3-I2C Power Monitor Carrier with Secondary I²C Isolation (Soldered Terminal Block).
according to description of product page, “The carrier board configures the ACS37800 to use a7-bit I²C target address of 0b1100000 (0x60 or 96) by default. However, the target address can be changed by reprogramming the EEPROM, as can many other configuration settings.”
but I did not find detail of that.
You can find more details about that in the ACS37800 datasheet, which you can download from the product page under the “Resources” tab. The relevant section is called “I2C Peripheral Addressing,” though in the PDF bookmarks it is labeled “I2C Slave Addressing.”
- Patrick
Thanks a lot!!
I found an Arduino Program to change I2C address there!
