Greetings,
I’m a new user and just purchased the Zumo 32U4 assembled.
I installed the ZumoShield V 2.1.0 from the library Mgr.
After installing the Zumoshield, I read the documentation and see that is should not be used.
Do I need to uninstall it? If so how?
Thanks in advance.
It shouldn’t be a problem to leave that library installed separately, but if you want to remove it, you can just navigate to your libraries folder, find the ZumoShield folder inside of it, and delete it. If you aren’t sure where your libraries folder is, it should be in your sketchbook location, which you can find by selecting the “Preferences” option under the “File” menu.
Brandon,
Thank you.
