I have been unable to upload code to my Zumo32U4 in windows 10 which has been working fine previously. I have tried both uploading before bootloader method, bootloader before uploading method and erasing the program with AVRDUDE. The Zumo32U4 is able to enter bootloader with the yellow light fading in and out and both the Zumo32U4 port and bootloader port show up in the device manager. Below is the verbose output in arduino for uploading. My zumo32u4 is connected to COM6 but for some reason Arduino forces a reset on port COM6 and then tries to upload to COM7 as seen below.
Thanks
Sketch uses 7454 bytes (25%) of program storage space. Maximum is 28672 bytes.
Global variables use 325 bytes (12%) of dynamic memory, leaving 2235 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM6
PORTS {COM4, COM5, COM6, COM10, COM11, } / {COM4, COM5, COM10, COM11, } => {}
PORTS {COM4, COM5, COM10, COM11, } / {COM4, COM5, COM7, COM10, COM11, } => {COM7, }
Found upload port: COM7
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM7 -b57600 -D -Uflash:w:C:\Users\matth\AppData\Local\Temp\arduino_build_533310/BlinkLEDs.ino.hex:iavrdude: Version 6.3-20190619
Copyright © 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright © 2007-2014 Joerg WunschSystem wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf" Using Port : COM7 Using Programmer : avr109 Overriding Baud Rate : 57600 AVR Part : ATmega32U4 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00 flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00 lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : butterfly Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: ser_recv(): read error: The I/O operation has been aborted because of either a thread exit or an application request.
avrdude: butterfly_recv(): programmer is not responding
avrdude: ser_recv(): read error: The device does not recognize the command.
avrdude: ser_drain(): read error: The device does not recognize the command.avrdude: ser_send(): write error: sorry no info avail
avrdude: ser_recv(): read error: The device does not recognize the command.avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = “F”; type = @
Software Version = �.w; Hardware Version = �.
avrdude: error: buffered memory access not supported. Maybe it isn’t
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.avrdude: ser_send(): write error: sorry no info avail
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloaderavrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
