I want to use a U3V70F12 to power a small LED array, but I want to be able to switch it (the U3V70F12) on and off via the enable pin using a raspberry pi zero. Since my input to the U3V70F12 will be anywhere from 5 to 11v, I cannot just connect ENABLE to a 3.3v pi zero GPIO pin since ENABLE is pulled up to VIN by a 100k resistor.
How can I drive the enable pin low via a gpio pin from the pi zero? I don’t want to use a mechanical relay since this project is very sound sensitive and I want to avoid the “clack” of the relay.
Should I be looking at an SSR? I don’t think I could use a transistor to accomplish this, but obviously I could be completely wrong in that assumption! If I were to remove the 100k pull-up, would 3.3v from a pi zero to ENABLE be enough to turn on the regulator?
Any guidance would be greatly appreciated!
